Taking a stab at an LS engine in my '99 Sonoma
Old Feb 24, 2009 | 01:46 PM
oct03gto's Avatar
I may have to PM you and get some of that harness info. As far as the trans, I have onenow. All built up and ready.
Old Feb 26, 2009 | 06:29 PM
Monza355's Avatar
More brake info please.
Thanks
Old Feb 27, 2009 | 05:18 AM
oct03gto's Avatar
Still working on it. I will do some detailed pics of the steering knuckle once I get the other side off to compair.
Other than that. The calipers are CTS-v fronts, and the rotors are C-6 Vette Z-51's.
Old Feb 27, 2009 | 07:24 PM
Monza355's Avatar
Thanks. I'll be watching.
Bill
Old Mar 1, 2009 | 07:59 AM
oct03gto's Avatar
No problem.
Old Apr 25, 2009 | 09:58 PM
car-zone's Avatar
I'd like to add that I still need some parts. List below.
Need Corvette A/C compressor and braket. With bolts if can.
Need a 2000 + F-body engine harness for an A-4 trans. Would like to have no EGR. But will deal with it if I can get a harness soon. No AIR system.
If close enough, would like to buy a low mile 4L60E trans from an LS equiped car or truck.
Need a Corvette front belt drive system with balancer pully, alternator, power steering pump, idler and tensioner pullies, brakets and bolts. (might buy brand new if I have to)
I also am looking for a complete charcole grey interior swap. And a body harness from an all power extended cab 2 wd truck.
Old Apr 26, 2009 | 08:48 PM
S10xGN's Avatar
PM sent...
Russ
Old May 8, 2009 | 03:00 PM
Petraszewsky's Avatar
Nice build...I'm putting a LS2 in my 2002 S10....I'm over on S10Forum as Petro...I'm still stuck on buying parts though....haha...It's gonna be a longer than expected..
http://www.s10forum.com/forum/f30/pe...roject-397265/
Old May 8, 2009 | 09:38 PM
cam75w/ls1's Avatar
Hmmh,where are you located? I just gutted a 2003 S10 (reg cab)that has all charcoal grey interior. I have everything but seats and carpet. Dash,headliner,visors,kick panels,rear wall carpet, and sill plates. If you can use any of this let me know. The harness I have is reg cab no power options.
Old May 9, 2009 | 04:22 PM
LS1GMCTruck's Avatar
Welcome to LS1Tech John. Are you in S. Florida?
Old May 12, 2009 | 08:47 PM
THE1320's Avatar
looking good. im starting mine soon. 02 s10 alum 5.7. i would rather do 6.0 iron, but i got a motor with a bad bearing for a fair price. as for the wiring, im looking into doing the same repin and reflash. what pcm does your 99 have, 0411?
Old May 13, 2009 | 06:33 AM
  #32
oct03gto's Avatar
It has the older type ECM. I would have to check the # on it.
Old May 13, 2009 | 09:41 AM
  #33
THE1320's Avatar
black case or bare aluminum? if it is the black, it is possible to upgrade to the 411
Old May 14, 2009 | 12:22 PM
  #34
oct03gto's Avatar
Black case. Going with the newer unit and converting the BCM over to a 2002 unit. Swapping power everything into it.
Old May 14, 2009 | 12:51 PM
  #35
THE1320's Avatar
cool. you building your own harness? if so, have figured out the wiring yet?
Old May 15, 2009 | 05:32 AM
  #36
oct03gto's Avatar
The body harness is out of another truck with the correct BCM. But the engine harness is still up in the air. I may just bite the bullet and buy one. I think in the end, it will just be money well spent.
Old Dec 6, 2009 | 07:56 PM
  #37
3rdgenfan's Avatar
Kurt please tell me you've touched this recently lol
Old Dec 7, 2009 | 05:56 AM
  #38
oct03gto's Avatar
I have. Just been taking my sweet *** time. LOL. Most of my spare cash has been going to fund a new home. So the build is taking slower than ever now. But I have been working on the frame, and getting all the ZQ-8 parts. The motor is almost done now too. A few body parts have been taken care of like the bed and doors. I've gotten the body control harness and module to convert to power everything. It's getting there.
Old May 14, 2011 | 11:03 AM
  #39
mcdonald77's Avatar
After reading the thread on long tube headers you still working in this. How about some pictures and updates!
Old Mar 15, 2017 | 11:55 AM
  #40
jgh64pkup's Avatar
Just found this on a search. Did you have more detailed pics on how you did the caliper to spindle mounts?
