LQ4 into a 3rd Gen/1972 Nova
Old Jun 5, 2013 | 12:43 PM
  #1281
bczee's Avatar
+1... Just Do It ! LOL
Old Jun 5, 2013 | 01:03 PM
  #1282
frojoe's Avatar
I took that pic at 11:30 last night! Saturday I plan to put a permit on it, get it emissions tested, and [hopefully] put plates back on it for the first time since Oct 2006. Geez I didn't realize how long this has taken until I just typed that date....
Old Jun 5, 2013 | 01:49 PM
  #1283
-TheBandit-'s Avatar
That is the same month & year I was diagnosed with cancer. Me and your Nova are doing a hell of a lot better now!
Old Jun 5, 2013 | 02:04 PM
  #1284
bczee's Avatar
Congrats to both of you !....
Old Jun 5, 2013 | 02:39 PM
  #1285
Marktainium's Avatar
That's if you're not too hung over from my Friday night birthday bash!
Old Jun 5, 2013 | 02:42 PM
  #1286
frojoe's Avatar
That's exactly why I've been busting my *** with laaate nights recently so that come Saturday, there's no work or thinking required
And congrats on the recovery Clint, doesn't seem like that long ago, does it?
Old Jun 5, 2013 | 03:17 PM
  #1287
No not at all. Time flies. Where are you going to go when you get it officially back on the road? I was under the impression you've been driving this car for a while, but I guess I was assuming incorrectly. Are you going to do some autocross or road course with it?
Old Jun 5, 2013 | 03:44 PM
  #1288
frojoe's Avatar
Definitely want to take it on the road course once I'm comfortable with it and the kins are worked out, will crash some of the local import auto-x's, maybe dragstrip once just for *****, but mainly a fun street car...
Old Jun 5, 2013 | 04:19 PM
  #1289
bczee's Avatar
To bad us Nova guys are not in one or a closer region.. would be great to get the cars together.. !
I know Pleasanton is having a Nova Mini Nat's Labor Day weekend.. ! If I don't go out of town. I will drop in.. many of the Steve's Nova Sites guys will be there..
BC
Old Jun 6, 2013 | 12:26 PM
  #1290
frojoe's Avatar
On the ground, ready to drive. Except.. the ******* thing won't fire. Cranks forever, gets good fuel pressure, proper injector pulse, MAP sensor reads maxed out. I have a hard time believing the MAP sensor went screwy since the last time I drive it and it was working fine. Going to go hunting for grounds, but this goddamn thing is really starting to **** me off. Could also be a bad PCM since I'm not getting a MIL light, tach, or speedo outputs from the PCM.
Attached Thumbnails LQ4 into a 3rd Gen/1972 Nova-wp_20130605_010.jpg
Old Jun 6, 2013 | 01:45 PM
  #1291
Did you disconnect all the electrical before welding?
Old Jun 6, 2013 | 02:45 PM
  #1292
frojoe's Avatar
I only disconnected the battery (positive & negative).
Old Jun 6, 2013 | 02:47 PM
  #1293
Chicago TDP's Avatar
I had the same thing happen to me once...I had a wire that chaffed that was causing the car to not start all the time...and I had one wire that was loose in a crimp connector that would cause the car to back fire...
Old Jun 6, 2013 | 05:45 PM
  #1294
tsnow678's Avatar
Is this the same problem you were having before when you were tuning it?
Old Jun 6, 2013 | 06:07 PM
  #1295
frojoe's Avatar
Only happened once. Was driving, **** went super rich, turned it off. HPtuners scanner confirmed injectors were flowing high because MAP reading was 193kpa. Did a Reflash Write and it was fine after. Now, despite Quick Write or Write Entire, it still reads maxed MAP pressure. With the MAP sensor disconnected it reads 90kpa. Something has always been suspect with the setup because none of my gauges that are hooked up to the PCM pin outs read anything. MIL light test doesnt work, speedo doesn't work, tach doesn't work. In HPtuners tho, tach/speedo read and display accurately. I wonder if there's some circuit that at some point got fried and it's contributing to a spotty ground for the MAP sensor as well as not letting the gauge outputs work. *****.
Old Jun 6, 2013 | 08:21 PM
  #1296
KY Nova's Avatar
That sucks for sure. The car looks great. Hope to see you posting it was something simple soon and the beast is alive again.
Old Jun 7, 2013 | 12:12 AM
  #1297
Check your input voltage to your map sensor. It should be 5v. If it isn't, say its higher, it could be a bad Zener diode or you have a gauge that is putting battery voltage back through your sensor source circuit. If it keeps going max map that would indicate a high voltage output from that sensor (5v or higher). Come drink with me tomorrow night and we'll trouble shoot it Saturday.
Old Jun 7, 2013 | 12:20 AM
  #1298
Also, if you are using the beta version of hp tuners, check your parameters for the map sensor as they are fully adjustable and may have defaulted to stock range.
Old Jun 7, 2013 | 12:37 AM
  #1299
gjestico's Avatar
You will solve this, You are one smart dude. Hope to see you out soon local. I want to see those Nova tail lights pulling away from me !
Old Jun 13, 2013 | 03:21 PM
  #1300
hookemdevils22's Avatar
joe, this thing still down?
