LQ4 into a 3rd Gen/1972 Nova
Made more progress. In one day, went from rough-cut-out of driver side stock wheel tub to a fully finish-trimmed area, just awaiting wire-wheel cleaning, framerail gusset welded in, and then final install and spot weld together.
On another note, passenger side is fully welded in and awaiting seam sealer and paint tomorrow.
After a lot of hammering and fitment it does look at home all welded in there. I've noticed that the rear half of the flange sits nice and flush with the existing factory [outer] tub flange, but the front half (essentially from the seat/trunk bulkhead forward) there was a consistent 1/4" to 3/8" gap that I had to hammer/stretch flush in order to spot weld the DSE flange. This was consistent on driver and passenger side DSE tubs, so not sure if I was cutting incorrectly or if the DSE tub is stamped slightly off.
And Mark, you missed a good thighmaster session yesterday...
I'm planning to paint my trunk floor and under the tubs with some Rust-Oleum hammertone black (maybe cover the underside with some spray-on undercoating I have), as I had to fill up holes I've drilled over the years. Plus it should help hide the patches. I had good results doing the cabin with their satin black. Something to think about...
