LQ4 into a 3rd Gen/1972 Nova
Also needed some 0.188" wall 2.0" SS304 for the wastegates to mount to, couldn't find it locally or on AceRaceParts.com, but did find it at OnlineMetals.com, which had a great selection of everything. Since I was already paying shipping for the SS304, I also got some 6" 0.100" wall 6061 aluminum that I'll turn into the surge tank for the trunk... eventually.
I was planning on trying a fixed tensioner someday. Might cure the problem ? Seems like going backwards tho.
I put a lot of work into getting my accessories low but to me it was absolutely worth it. It really tidies things up. You have a little more wrap on the alternator pulley than gjestico so hopefully that helps, but nothing beats real world experience. It sounds like belt sequel could be an issue.
Going to a fixed tensioner means it wont compensate as the belt stretches. I don't know if that will be a problem in normal use or if it would just need eventual adjustments.
Because of the camber gain from the Gulstrand mod, at full steering lock the outside tire comes closest to the trimmed fender lip around ride height, and the gap is about 3/8". Any suspension compression past that and the camber gain tucks the rim in and that gap decreases a bit to 1/4" or a little under, but then remains at that until full bump.
Because of the greater steering angle due to Ackerman, the inside tire at full lock just barely starts to rub the fender lip at full lock at ride height, and then continues to rub worse as the tire compresses. So this is okay for parking lot full lock, or hard corners as the car rolls a bit.. but the inside tire will rub the trimmed fender lip pretty bad with any compression from hard braking while at full lock. I guess I can't Gymkana this car.
The driver side, at full right steering lock...
Here is the driver side cycling thru the suspension, with a pause around half way thru at what ride height would be if there were a spring in and on the ground...
And passenger side, full right lock...
But first, some Precision equipment in a not-so-high-precision shed of a garage! Haha
And here are some comparison pictures if this helps anyone else out there. In all my research it was really difficult to get any reliable outside dimensions from any turbo maker, so here is a sizing comparison of the 6466 to a Turbonetics TC-76.. they're practically identical in size. That Turbonetics is one small envelope for a 76mm turbo. No wonder it choked out and wasn't nearly the beast that the old PT7675 was.
I spent about 2 hours methodically changing the x & y location of the turbo as well as the height, trying keeping it inline with the engine then a variety of angles to try and get the combo of best angling for the pre-turbo hotside (and downpipe) and tire clearance at full lock.
The pre-wastegate hotpipe is 0.188" wall schedule 40, so it's also on the thick side, but I think I will add a gusset just because the crotch weld in the front will end up being pretty sharp.
There is about 3" of airgap between the pre-turbo hotside and the P/S reservoir cap, which should be far enough considering there will be relatively-cooler air blowing in that area from the rad fans. I may still make a heat shield or heat tape the top of the reservoir cap.
There is also 1.5" air gap between the wastegate downpipe and the mockup of the radiator fan. The rad+fans mockup is generous (3.5" thick radiator) but the fans are also placed pretty high up, I could move the fans down a bit in real life, as well as the option of moving the rad down ~1" as well.
There was no good way to take a pic of this, but there is a minimum 1/4" gap between the wastegate downpipe or bellow and the pre-turbo hotside.. I think with the bend welded to the turbo downpipe, even with head expansion and vibration, there's no way this bend would rub on the pre-turbo hotside.
And of course, I went thru the effort to make the Precision logo horizontal
