68 camaro efi
Old Sep 6, 2008 | 12:21 AM
firstgenguy's Avatar
Default 68 camaro efi
Has anyone used there stock first gen camaro tank for a fuel injection setup? I would like some ideas instead of buying a 600 dollar rock valley tank. Wondering if there is another intank pump unit that will work in the stock take. Thanks for any help.
Old Sep 6, 2008 | 12:40 AM
fmf816's Avatar
I'm doing a ls1 in my 68 Camaro and I was told by a few people on here that a Walbro in line pump works great. I just got one and I think it was around $50. Hope that helps!
Old Sep 6, 2008 | 02:19 AM
poconojoe's Avatar
What are you going to do for a return line?
Old Sep 6, 2008 | 09:38 AM
JAY ROD's Avatar
I just did a swap in a 69 camaro.I used the stock tank with a stock sending unit that had a return line on it.I then used walbro 255 inline pump with a external regulator.Works perfect but don't let the tank go below 1/4 full.
Old Sep 6, 2008 | 09:42 AM
fast's Avatar
search the stickies, lots of great info
vette reg/filter combo
Old Sep 6, 2008 | 10:51 AM
radrambler's Avatar
Default camaro tank efi
hi
use the c5 vett filer/regulator that has a return coming off of it...and return it back if your sending unit.if it already has an return tube (some do some dont) if not .drill hole in sender and add a fitting to hook a hose to and your ready to go.
ive know people to use this method and it worked fine
radrambler
Old Sep 6, 2008 | 05:25 PM
I have a -8 an fitting welded on the stock tank with a inline pump. Works great till I get low on gas and going around corners. Just wanted to know if anyone was doing an intank setup. Thanks
Old Sep 7, 2008 | 11:41 AM
Rodder's Avatar
I'm running the stainless Rock Valley tank... I plan on keeping the car forever, and don't plan on ever having to replace the gas tank again.
Old Sep 8, 2008 | 04:16 PM
68sstt's Avatar
I used one of these has proper baffling and high volume intank pump with return line and thing looks original
http://info.rockauto.com/SPI/Detail2.html?m_gm32afi.jpg
Its $450 but thats cheap for insurance against fuel surge
Old Sep 8, 2008 | 04:35 PM
cacmanjr's Avatar
rockauto (www.rockauto.com) sells a spectra premium 1st gen tank with the pump and pick up for $449.
Old Sep 8, 2008 | 11:11 PM
leonpiper69's Avatar
i used the in tank kit thats is in the sticky, that olly did. the one form tanks inc. comes with the pump and hardware, instructions and pretty easy to do, plus its quiter than an external pump and should last longer. people often forget that the fuel acts as a coolent to keep the pump from burning up, so the people that drive around on e burn up pumps faster. same idea as an external pump.
on a race car thats fine it doesnt run that long but on a street car i hgh volume pump will get hotter than a stocker and really benefitts from the gas kepping it cool.
just my $.o2
