which color wires of Ign. Switch w/PIX
AWESOME>![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
THANKS thanks.....
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
At Turn Signal Switch color wire:
white> brake ligt switch
green> right rear turn signal and brake light
yellow> left rear turn signal and brake light
purple> turn signal flasher
brown> emergency flasher
blue> right front turn signal
light blue> left rear turn signal
black> horn
lime-green>
tan>?
give me time, I'll try to find more.
black> horn
lime-green>
tan>?
white> windhield wiper power (although everything I've seen is yellow)
gray> windshield wiper delay/slow
green> windshield wiper mist
purple> windshield wiper high speed
pink> windshield wiper washer pump
black> cruise control resume/accel
blue> cruise control set/coast
gray> cruise control on/off
pink> power for cruise
I don't know if a universal one will fit in the column. A GM style key switch will probably use a stock connector anyway. You don't have any of the interior harness or something?Yes, I install the fusebox/wires execpt that steering column wires and rear stoplight wires.
Here is where the stock igintion switch was located. It is connected to this rod . Try moving the key and see if the rod moves back and forth. The connector I showed you is the original that plugs into this switch. As far as the nutreal switch I have never seen anyone use one in a car. Only a clutch switch which you are also missing in the pix
![Name: 2001CamBlueV-6503.jpg
Size: 69.0 KB](https://ls1tech.com/forums/attachments/conversions-swaps/622798d1501363603-color-wires-ign-switch-w-pix-2001cambluev-6503.jpg)
I can find you a switch that will work. You can reuse the clutch switch if you need to. Just because you are not using the PCM does not mean you can not reuse the switch. I can draw you up the wiring if you need help.
#32
Looking at http://www.acdelco.com/index.jsp. No show on that #... I ll check on GM part shop TRW..Thanks
PT289
#33
I look for connectors at brake bracket switch for hot wire from ignition switch and goes to stop lights.
![](http://i98.photobucket.com/albums/l268/dy21247/2001CamBlueV-6476.jpg)
which correct?
FINALLY, That stoplight works!!!!
Small box start with left>right:
1)
2)
Long box start with left>right:
1)
2)
3)
4)
which correct?
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
1)
2)
1)
2)
3)
4)
#36
Finally, I found that OEM switch ignition connector/rod. look at #25
![](http://i98.photobucket.com/albums/l268/dy21247/2005ChevyCobalt489.jpg)
![](http://i98.photobucket.com/albums/l268/dy21247/2005ChevyCobalt367.jpg)
I need switch ignition only.
what part # I need to buy for ignition switch? 1405B? I will go O'Reilly to look up that part #.
