which color wires of Ign. Switch w/PIX
Old Sep 11, 2008 | 12:16 PM
Jeff Smith's Avatar
Default which color wires of Ign. Switch w/PIX
I need to know, which color wires under steering column- Ignition switch key from Camaro V6. I am working on LS2 Carb. Motor/01'Camaro.
I need to know which color goes connect to:
1) Ign. Switch >Accessories
2) Ign..Switch> BAT. Or Power
3) Ign.. Switch> IGNition
4) Ign.. Switch> Neutral Safety switch
Relating to Netural safety switch- I already remove the safety switch at Manual 6 spd.
Old Oct 1, 2008 | 10:57 PM
Jeff Smith's Avatar
I stay on. No ones could help.....
Old Oct 1, 2008 | 11:15 PM
ryanvv355's Avatar
I am thoroughly confused
Old Oct 1, 2008 | 11:24 PM
Jeff Smith's Avatar
Really....Let me re-do...
Old Oct 2, 2008 | 12:26 AM
TPI TERROR's Avatar
what exactly are you trying to do>?
Old Oct 5, 2008 | 06:37 PM
ddcarter's Avatar
What year camaro? 01?
Old Oct 6, 2008 | 06:08 AM
Jeff Smith's Avatar
Finally, I took the steering wheel out from under column and look for the wires goes to and from. It is 2001 Camaro v-6 and now install LS2 Carbed Motor without CPU. Also I keep that OEM steering column.
Anyone who know which those color wires goes to?
At Turn Signal Switch color wire:
white>?
green> ?
yellow>?
purple>?
brown>?
blue>?
light blue> ?
black> ?
lime-green>?
tan>?
At Multi-Function Lever color wire:
white>Fused Output- Accessory ?
gray> windshield wiper -signal on ?
green> windshield wiper- low speed ?
purple> windshield wiper- high speed ?
pink> windshield wiper signal ?
black> cruise control?
blue> cruise control?
gray> cruise control?
pink> fused output-Ignition?
At Ignition Switch color wire:
white>
white>
which I should connect on two white for ignition switch? At ignition switch position, Start and Run? ACC.?
Appreciate for input.
Old Oct 6, 2008 | 01:28 PM
Yeajimi's Avatar
Check out a FSM, Haynes or Chilton manual. They will label each.
Old Oct 6, 2008 | 11:32 PM
Jeff Smith's Avatar
I want to make sure those wires are correct in order???
ACC (Accessories)>>Alt. Exciter) Alt. Exciter wire from Alternator and to Fuse box and connect to Ign. Switch marker >Accessories
IGN (Ignition)>> Coil wire goes to Fuse box and connect to Ign. switch marker> IGN.
BAT>>Starter Solenoid (“+” terminal) wire from fuse box and connect to Ign..Switch marker> BAT.
ST (Start)>>Starter Solenoid (“S” terminal) wire from fuse box and connect to Ign.. Switch> START
I can't get info. of manaul book..Anyone may know ????
LS1 Manual showed Ignition switch in order (clockwise) is:
1. ACC. > Connect to ACC.
2 Lock >
3. Run >???? or connect to Starter Solenoid "+"??? or Connect to IGN.
4. blub test >????
5. start > connect to Starter Solenoid "S"
Old Oct 7, 2008 | 10:43 AM
Schitzo's Avatar
places you can find wiring diagrams
1.Chilton manual. You can buy this at your local auto parts store....napa,autozone,etc
2.Alldata. Your local library
3 Mitchell . Your local library
4. GM Dealer. If you can convince them to get you the info
I get all my wiring diagrams from my library. It costs 5 cents to print a page.
I'm looking through my Chilton Camaro/Firebird 1993-2002 Repair Manual and cant find the info you need.
Old Oct 8, 2008 | 08:51 AM
Jeff Smith's Avatar
Really,No time to go Library to do search. I could do serach on this forum at my garage. Works>works>works>home>home. I have to take care to my family after work. I wish go
I sure, all of you LS1Tech guys had know or experience with that.
I will try find my time for Library...
Thanks...
Old Oct 8, 2008 | 08:33 PM
ddcarter's Avatar
Are you still needing help?
Old Oct 9, 2008 | 10:47 AM
Jeff Smith's Avatar
PM you....
Old Oct 9, 2008 | 05:53 PM
ddcarter's Avatar
You should be looking for a connector that looks like this. I think it is a two part plug. It should have a rod going inot it from the actual key switch. It is located at the bottom of the steering colum where it goes into the floor.
RED hot from battery
YELLOW hot in start
BROWN hot for accessary
PINK hot fin ign
I think these are correct if not let me know. Is there any way you have to test to make sure. If not let me know and I can look in some more places
Old Oct 10, 2008 | 09:01 AM
Jeff Smith's Avatar
Look #7 picture, those wires from Steering column are there what I look. That is all.
Those wires are 2- 11 pins flat connectors and small connector (Orange heat shrink )22 ga> (that goes to Lock Cylinder Ignition switch).
DDCarter, your pix is not same what I was looking.
Let me send you more pix after lunch..
Old Oct 10, 2008 | 10:32 AM
loweredd's Avatar
I don't understand the need for the wires. I looked at schematics for an hour and a half, but can't come up with a diagram for that connector. I know which one you are talking about, but don't know if your 01 will be the same as my 79. Blinker wires should all be the same color.
What are you doing with the connector?
You shouldn't have to do anything with this connector if you are getting rid of your computer to run a carb.......
Old Oct 10, 2008 | 10:59 AM
loweredd's Avatar
white>?
green> ?
yellow>?
purple>?
brown>?
blue>?
light blue> ?
black> ?
lime-green>?
tan>?
white> brake ligt switch
green> right rear turn signal and brake light
yellow> left rear turn signal and brake light
purple> turn signal flasher
brown> emergency flasher
blue> right front turn signal
light blue> left rear turn signal
black> horn
lime-green>
tan>?
give me time, I'll try to find more.
Old Oct 10, 2008 | 11:15 AM
loweredd's Avatar
Lime green> high beam lights (for dimmer)
tan> low beam lights (for dimmer)
Old Oct 10, 2008 | 11:39 AM
loweredd's Avatar
white> windhield wiper power (although everything I've seen is yellow)
gray> windshield wiper delay/slow
green> windshield wiper mist
purple> windshield wiper high speed
pink> windshield wiper washer pump
black> cruise control resume/accel
blue> cruise control set/coast
gray> cruise control on/off
pink> power for cruise
Old Oct 10, 2008 | 01:30 PM
Jeff Smith's Avatar
I set up the fuse box mount on middle.
ACC>>Alternator Exciter ( #1=R) #14 White (14GA.) wire from Fuse box under Dash , then it change to #33 Orange (14GA.) wire at Fuse box under dash, And it goes to Ign. Switch marker>Accessories (ACC.)
IGN>> MSD Coil positive side (+) #20 Pink (14GA.) wire from fuse box under Dash, And it goes to Ign. Switch marker >Ignition (IGN.)
BAT>>Starter Solenoid (“+” terminal) #34 Red (10GA) wire from fuse box under dash, And it goes to Ign..Switch marker> BAT.
* Add Voltmeter Gauge
* All Gauges
ST>>4) Starter Solenoid (“S” terminal) #19 Purple (10GA) wire from fuse box under dash, And it goes to Ign.. Switch marker> Neutral Safety switch (S)
I want stay OEM Steering. I look for where wires (white ACC., red BAT., pink IGN., purple ST.) are from that OEM Steering column -Ignition switch wires and multifunction, should connect to the fuse box.
Pix here..
