which color wires of Ign. Switch w/PIX
steering column from a 99 camaro using in a ratrod
all harnesses are on column
ignition switch
blue harness
yellow / hot in start ..... starter solenoid ?
brown / accessory ......radio mem and stuff ?
red / hot from batt
2pinks same pin ? fin ign ?whats this one for
black harness
org whats this one for?
i also seen yall did the turn signals and wipes and stuff but my wires are diff here thy are....
harness #1
pin#D= 2 yellows same pin
pin#E= green
pin#F= gray
pin#G= purple
pin#H= pink
pin#J= gray w/black line
pin#K= blue
pin#L= gray
pin#M= 2pinks same pin
harness #2
pin#N= green
pin#M= yellow
pin#L?= purple
pin#K= brown
pin#J= 2 dk blue w/white line same pin
pin#H= 2 lt blue w/white line same pin
pin#G =2 blacks same pin
pin#F?=light green
pin#E =black
im also using a after martket fuse box with wiring
if need the fuse box wires and labels on wires let me know
plz hlp been lookin for this info for about 2mos or more
thk you
