Vortec 5700 swap
I am going to be learning lots thru this project and will be asking lots of questions. Does anyone have any advice on the wiring and the easiest way to figure out which wires are needed and which ones need to be spliced? One suggestion that I was given was to get the bulk head connector from a 97 truck for under the dash and splice it into the wiring, replacing the one that is already in my car. To me, this doesn't seem necessary. I thought it would be easier to find the correct wires for my dummy lights and just splice into the 97's harness and wire it directly like that. Any input?
That plug is probably not necessary as only a few wires will have to run inside the vehicle.
Re'
Good luck with your swap.
Re'
I'd love to have any wiring diagrams you have available. My email address is livyx@yahoo.com
Thanks.
Here is most of the information you're going to need (great site with tons of great swap info, can't remember the owner's name/username (brendan maybe?) right now but he's posted plenty of projects here and deserves all the credit):
http://www.lt1swap.com/1999_vortec_5.7/index.htm
http://www.lt1swap.com/1996_vortec_5.7/index.htm
This is a great place for the L31 guys
http://www.pacificp.com/forum/viewfo...3861deba8e4125
Should be an easy swap overall...hope this helps
Thanks.
