Fuel Pumps?
Old Oct 9, 2008 | 07:56 AM
ridenlow71's Avatar
Default Fuel Pumps?
I'm swapping an LS-1 into my 71 cutlass. I've looked through the topics but haven't seen anyone talk about what type of fuel pumps to use. I know you have to have 60 psi of pressure. Would and electric fuel pump work and just mount it on the frame? Help me out please
Old Oct 9, 2008 | 08:09 AM
stealth71's Avatar
There are a couple options.
1) Extrernal pump inline
2) Modify your tank for an intank pump like Tanks Inc.
3) Swap your tank for one with an internal pump. ~'96 Impala or Aftermarket (Rick's)
I went with a Impala tank in my '71 Chevelle swap.
Old Oct 9, 2008 | 09:37 AM
red83's Avatar
From: sneaking in your back door as you leave!/cartersville ga
just a few threads down on page 1
https://ls1tech.com/forums/conversions-swaps/997900-what-fuel-pump-search-engine-down-my-end.html
Old Oct 9, 2008 | 11:00 AM
lsxmalibu's Avatar
I used the cheap E2000, mounted it on the frame, and used the stock pick-up. Worked fine on a 6.0.
http://cgi.ebay.com/ebaymotors/NEW-F...4506.m20.l1116
Old Oct 9, 2008 | 12:07 PM
bczee's Avatar
I like Stealth71 is using a Impala tank with a Walbro 255 pump, connected to a 99+ Vettet FPR.
These 94-96 Impala tanks will fit in you frame without too much work.. a small trim (1/4") on each frame rail and moding the straps to secure the tank. The Fuel level sender should also work with your Stock Cutlass gauge as they are the same ohm rate. another plus is that you get a few extra gallon of fuel.
One of the main concerns of a High Pressure EFI system is fuel starvation on stopping, turning and acceleration !.. If the stock tank is not setup with baffles and a sump you might need to keep at lease 1/4 of fuel all of the time, else you rise leaning out the system when the pickup come out of the fuel as it is moving around. The Impala has both a bucket and some baffles.
Using a external pump can be noise and service life many be short. Get a good one if your going that route.
Many who have used external pump will add a weld on sump (Competition Engineering markest one) to the bottom of the tank. This works ok, but one word of warning.. having the fuel pickup exposed might be considered illegal in some area and the Cops many use it to stop and give you a ticket for it.
let us know what you come up with.
Old Oct 9, 2008 | 12:42 PM
ryanvv355's Avatar
I have the Spectre tank, no issues except I need a bigger pump to keep up with the blower.
Old Oct 9, 2008 | 04:18 PM
Eric Anderson's Avatar
+1 for the Impala tank set up. You will need to cut an access thru your trunk floor though. This already came in handy as I already went thru one Walbro.
I bought a replacement that I think is a Bosch. I'm now having starving problems when below 1/2 tank. I'll have to see if the set-up is higher off the tank bottom than with the Walbro...
Eric Anderson
68 Cutlass LS1/4L60E
Old Oct 9, 2008 | 10:22 PM
6spdgto's Avatar
x1000 RockAuto >$500 looks completely stock
Old Oct 9, 2008 | 10:45 PM
pist0lpete's Avatar
Another options not mentioned is to get one of the tanksinc in tank pump setups. Basicly you cut a 4" hole in the top of your tank and put an in tank pump in that has its on bucket it sits in to prevent starvation. That is what I have used and so far (limited driving) it has worked well. I would say for your money the Spectre tank is by far the best since it should work great and looks stock. However if cost is an issue the impala swap is tough to beat cuz they can be had for cheap.
Old Oct 23, 2008 | 08:52 AM
ridenlow71's Avatar
I found a complete ready to go tank from a company in ILL called the parts place inc. It's a little pricey so I'm debeting right now.
Old Oct 23, 2008 | 09:12 AM
ryanvv355's Avatar
That would be the Spectre EFI tank, they list it for $595. Rock auto has the same tank for $451
Old Oct 23, 2008 | 11:00 AM
Bad Chad's Avatar
I'm using the Aeromotive 1000 for my swap.
Old Oct 23, 2008 | 01:05 PM
ridenlow71's Avatar
cool thankss
Old Oct 23, 2008 | 01:07 PM
ridenlow71's Avatar
does rock auto have a website or is it rockauto.com?
Old Oct 23, 2008 | 01:34 PM
ryanvv355's Avatar
yup, rockauto.com
