Convertible Vehicles Enthusiasts | Information | Maintenance
Pro Kit
Old Oct 30, 2008 | 06:42 PM
kbronSS's Avatar
Default Pro Kit
so automatically a vert will look or be lower on the back than in the front if lowered?????
Old Nov 1, 2008 | 01:11 PM
pjmayher's Avatar
I have had the pro kit on for over a year and close to 15000 miles and there is no sagging in the rear. It is perfectly level.
The only problem I had is the bump stop wore out.
Old Nov 3, 2008 | 09:25 PM
dpw41285's Avatar
my rear was way lower, i ended up doing the hose mod on stock springs and prokit up front.
Old Nov 4, 2008 | 05:57 PM
pjmayher's Avatar
What is a hose mod?
Old Nov 5, 2008 | 12:43 AM
94Z28rag's Avatar
Originally Posted by pjmayher
What is a hose mod?
+1???
I have Pro-kit and am slightly lower in the rear. No change in 2 years.
Old Nov 5, 2008 | 12:44 AM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
METOO.
Old Nov 5, 2008 | 09:39 AM
TRANS-DAD's Avatar
What is a hose mod?
The hose mod is when you remove the stock isolators from the top of the spring and replace it with a piece 3/4" heater hose on the top coil of spring
( to keep it from being metal to metal ) This will give you about 3/4" drop
in the back
LOOKS GOOD AND RIDES BETTER THAN SOME AFTERMARKET!!!
Old Nov 5, 2008 | 07:42 PM
pjmayher's Avatar
Okay I guess that makes sense. Thank you.
Old Nov 10, 2008 | 06:22 PM
spaz1's Avatar
I had a pro kit in my car it measured 25.5" to the top of the wheel well opening in front and 26" in the rear. I took it out after I put the sts kit in. It has like a 1000 miles on it. It is for sale make me an offer.
Thanks,C
Old Nov 11, 2008 | 05:42 PM
pjmayher's Avatar
Here is my pro kit after close to 20K miles.
