New vert', a few questions
First - do you need the tonneu cover over the top, or is just an asthetic thing. I can't find a reason to "have to" put it on, but this is the first vert I've ever owned, so I want to be sure.
Second - how much do I have to worry about twisting the body on this car? At what power level, or amount of hard cornering, does that become a factor. I like to auto-cross, drag race, and mod for more power on anything I've ever had, but this 'vert is super clean, and I don't want to tear it up at all. I understand the 'vert models were designed to be convertibles, and not just modified from coupes, but to what extent?
Thanks for all the input in advance guys.
Guess it would keep the section of the top headliner from fading from the sun that shows when the top is down, I have noticed mine is faded some.
I wouldn't bother with it.
So is your interior tan or your top? Mine started out as a Red/Tan Top/Grey Interior car, now it's a Red/Black Top/Tan and Black Interior car, I don't miss the tan top at all for what its worth.
Good to know these verts handle heavy use well, I guess I'm still in my third-gen mentality, where anything that wasn't a hardtop needed SFC's or you'd crack the body in no time.
Oh and nice color combo
However, the cover does finish off the sleek F-body nicely.
Good to know SFC's arn't a must have - I would like to get a set, but that will probably have to wait at least a little while - first things first, the salad shooters gotta go.
SFC are not a necessity, but they are a niceity to reduce cowl shake and firm up the ride. I noted that my car launches much straighter after adding mine.
there are reinforcements to the subframe from the factory (you can see them if you look under the car), so normal driving is fine.
if you're into taking corners faster than an old lady on a sunday drive, the subframe connectors will help. i found the flex made things a little less predictable at speed when you set the car in a corner. with the subframe connectors, it is better. i also use a shock tower brace.
nice find on that LT1
