What are the NHRA rules for a rollbar?
You will also need a helmet (snell 2005 or newer), 5 point seat belt (not sure the limit that this is required) and if you want to run with the top down you need to have the wrist straps.
I know that IHRA rules state that you have to have padding on the cage anywhere your helmet can come in contact with the cage. So depending on how hard they tech your car at your local track you may want to consider that as well. I padded mine, looks better IMO...
13.49 and quicker 5 point bar - as stated above.
This will get you to 10.000
quicker than that? 10 point.
The rules also say that if you're fast enough for a bar, you must have a 5 point harness as well.
So, yeh, a stock vert could very likely need a bar.
Some tracks will allow for a hardtop - fiberglass or what ever. Like from Smoothline or Carravaggio. and you can run to 11.49 - same as a hardtop car.
So far, I've only been yelled at a couple times... Once for going 13.0 at 88mph on the brakes... lol
Sometimes at test and tune nights they will let you go - depends on the track. but for any type of competition, you will likely need a bar.
