Rattles in convertible cars
I noticed most of thuds noises come when the top is up.
Any one else feel this way too or is it because they aren't heard as much with top down?
Roads here are terrible and the car was a dd stock suspension for 10+ years.
I put in monroe shocks , nothing special just aftermarket replacements that cured some of the rough ride and rattles.
Any ideas on maybe tightening the top or if verts have more rattles than a ttop car?
Also look into replacing any rubber suspension parts, including trans & motor mounts.
NC01TA - Thank you for those suggestions, Its something quick and easy I can try.
libertyforall1776 - Konis are most desirable but I may go with billesteins and use rest of funds for replacing the mounts and rubber suspension parts like you said.
I see that strano parts has a rebuild kit. Is this everything needed for front and rear?
https://ls1tech.com/forums/suspensio...ll-almost.html
What rebuild kit are you referring to? It's best to post the link.
Definitely want some SFCs on that Vert -- makes a world of difference, and dump the crappy Monroe shocks. Add some Strano sways instead of swapping sway bushings, and put in a STB.
Also check your trans mount, motor mounts and rear bumpstops -- any cracking or disintegration then replace them.
When I bought the car, it had Konis (front) and Bilstiens (rear), with rear LCAs. I have installed UMI 2-point SFCs (3-points were not available at the time, or else I'd have gotten those), UMI STB, and Strano hollow sway bars (35mm/19mm). I have no squeaks anymore EXCEPT for when I first start driving after the car has been sitting for a week or so. After about 20 minutes of driving (accelerating, braking, turning corners, speed bumps, etc), the squeaks are all worked out and the ride is quiet.
I will also +1 Sam Strano's sway bars, and am eager to get the springs as funds allow. UMI also makes a nice product. Noticed an instant difference when I installed my bolt-on subframe connectors. Didn't notice much difference with STB, but bought one just cause I have a 'vert and was more of a preventitive measure to guard against flex/twist.
