Convertible Vehicles Enthusiasts | Information | Maintenance
LS6 Block
Old May 22, 2017 | 07:50 PM
2006 Denali's Avatar
Default LS6 Block
Purchased my 2001 WS6 Convertible about a year ago.After driving it a while I heard what sounded like some bad lifters. So with that excuse I pulled the engine. I could not find the 5.7 or LS1 anywhere on the block. I found what seemed to be ID numbers.So I went to the enternet for some help. Based on the info I found on the Net and the number from the block (12561168) I have a LS6 block. From what I found GM installed them on a few 2001-2002 F-Body's.With of course LS6 intakes & injectors. My question is to all you F-Body owners. Have you checked or if you already know that you do or not.Will you guys please chime in if you have a factory LS6. Also if anyone has any info like production numbers of these cars or anything please tell others and my self about it. I have not found much info on them. Thanks Guys
Old May 22, 2017 | 08:18 PM
farmington's Avatar
All 2001-2002 LS1 engines got LS6 intakes. A LS6 block adds nothing. It's just a different block casting number, nothing else.
Old May 23, 2017 | 11:15 AM
Already knew that info.Was not insinuating that they are (Special) was just asking if anyone had any other info!!?? Like production numbers or something. This is why I don't post much. People don't take the time to read the question. They just start bashing.
Old May 23, 2017 | 11:28 AM
JohnnyBs98WS6Rag's Avatar
RPO code LS6 was never applied to any LS1 F-body, so there is no way to accurately quantify quantities of cars built w/ a LS6 block casting. To come close, you'd probably have to find production records from the engine factory / block foundry to determine the total # of LS6 blocks cast within the '01-'02 MY production runs, and subtract the number of Z06 'Vettes built from that. Even that approach would be flawed, because if f-bodies received LS1 engine assemblies that were built on LS6 blocks, how many non-Z06 '01-'02 'Vettes received them too?
I suspect that at some point, the LS1 assembly line transitioned from using LS1 block casting to using LS6 block castings. Proof / debunking that theory would be determined if any '03+ 'Vettes or '04 GTOs had LS1s w/ LS1 block castings.
