Has anyone raise the front tires off the ground?
Like the title says, wife has always wanted me to get the tires off the ground. But in a vert with no drag susp. mods, I doubt that will ever happen.
What have you guys done to achieve this. ie.susp?,motor?,tires?
Thanks
Thanks
Location: LOT"S OF BOLT-ONS, GADGETS, SWEET & LOUD PIPES, HYPERTECH P.P. 160 T'STAT BLAH, BLAH
![Cool](https://ls1tech.com/forums/images/icons/icon6.gif)
...MY VERT WILL BURN A LONG-*** TRAIL 10-20 FT OR SO AND ITS AN A4, BUT I THINK THE TWO KEY ELEMENTS ARE TIRES AND TORQUE. I CAN'T GET
THE FRONT OF MY HOG UP EITHER, ALL IT DOES IS BURN AND FISHTAIL (WHICH IS KINDA COOL IN ITS OWN RIGHT)
![Shakinass](https://ls1tech.com/forums/images/smilies2/shakinass.gif)
Yea I have only had my car to the track once and I broke all the wheel studs off of my moser 12 bolt. But that was on my second pass. My first pass I only launched at 2000 and it pulled the front end about a foot and a half. It wouldve really come up the second run when I launched at 5500 if the studs wouldnt have snapped. Ive got a 383 6 speed, 12 bolt, and all suspension, so i wouldnt count on it with the stock rearend, but with a good rearend you could do it with out other suspension I think.
Billy
Billy
If that's your only goal it shouldn't be all that hard. Get a short torque arm, LCA's, some sticky tires, and dump your clutch on the rev limiter. If that doesn't do it, then you broke something.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Originally Posted by SMOKINV8
If that's your only goal it shouldn't be all that hard. Get a short torque arm, LCA's, some sticky tires, and dump your clutch on the rev limiter. If that doesn't do it, then you broke something. ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
I did once crossing Kennedy on McDill when I first moved to Tampa, going 65 to cut off a vette, cross street was pitched so steep the front was airborne, k-member and oil pan show evidence of the destruction.
I'm getting close.
http://img155.echo.cx/img155/4228/joerokicsak3jj.jpg
as far as suspension I have
Strut Tower Brace
Sub-Frame Connector's
Lower Control Arm's
and I'm adding a Torque Arm next week. I've got pretty much all the bolt-ons minus the LS6 intake which is going on soon and no pullies.
Strut Tower Brace
Lower Control Arm's
Originally Posted by Rok
I'm getting close.
Strut Tower Brace
Lower Control Arm's
Strut Tower Brace
Lower Control Arm's
wow, looks like a lot of squat there. have you considered getting an anti-roll bar yet? that should help it lift the fron end more i would think!
Dave
What 1/4 times you got and what differential you run?
I'm getting close.
Strut Tower Brace
Lower Control Arm's
Strut Tower Brace
Lower Control Arm's
My best that day was a 12.94 @ 107.xx with a 1.94 60'. I should be faster but at the big end I seem to be falling on my face. hopefully my new intake and retune will help with that.
All I have is the stock anti-roll bars. would an after market one really help that much?
wow, i thought you were much faster judging by how much lift you seemed to have. i can't say for sure if it would if you're in the high 12's. might want to spend that money else where for now like the wheels or k-member or something. just my oppinion.
