Convertible Vehicles Enthusiasts | Information | Maintenance
drop it or put on sfc?
Old May 4, 2006 | 10:11 AM
gyrene2003's Avatar
Default drop it or put on sfc?
What do u guys think, birthday coming up, should i go with SFC or lowering springs? I think SFC would be the responsible choice but i really want to get that ride hieght right? just tell me what u guys would do!thnx Also i put this in here cause i figured u guys would be alittle more fitted to me cause i have a vert!
Old May 4, 2006 | 10:36 AM
Roadhouse's Avatar
Springs would be less expensive ( if you put them on yourself ) and LOOK good. SFC's are a little more expensive for Vert's but tighten the car up so it'll FEEL good. Maybe you could find springs and SFC's used for a good deal here or on Ebay.
Old May 4, 2006 | 10:45 AM
gyrene2003's Avatar
thnx man, thats a good idea and i like the way u think!!!!! Also what are some good brands for SFC?
Old May 4, 2006 | 10:59 AM
Roadhouse's Avatar
I don't know all that are available. On my SS I have the SLP bolt on's.
Old May 4, 2006 | 11:01 AM
gyrene2003's Avatar
what did they run u? Are u a vert?
Old May 4, 2006 | 12:32 PM
TA guy's Avatar
If you do springs you really need shocks too (especially if you are running stock) or your ride quality will be really poopy, and your handling may not show much improvement with only springs, due to poor damping. Also, good shocks will make the SFCs much less important, some would even argue useless.
So, what I am telling you is to go with a spring/shock combo or koni SA shocks alone if you are only looking for a 3/4" drop (they have an optional lower spring perch, and then the rear springs get the heater hose mod)
Old May 4, 2006 | 12:42 PM
TA guy's Avatar
FWIW, I only noticed a very slight difference in the feel of the car with weld in SFCs. However, new shocks were a huge difference (bilstein HDs, not acceptable for use with lowering springs), the shocks made the car handle better and a more comfortable ride. This was with 25k miles on the clock, the stock shocks (on their best day) are really bad. Call Sam Strano at Strano parts for advice on exactly what to buy to achieve your goals, he knows his stuff.
Old May 4, 2006 | 01:27 PM
Josh2006's Avatar
well i got the springs before SFC and my SFC are still waiting for instal
i got BMR SFC and i have heard nothing but good things from them so that what i got
like was said pay attention in the parts for sale section i got NIB BMR springs for 150 and installed them myself so they werent that expensive and i bought the SFCs new so they were 200 if you install your self (hope you know how to weld)
-Josh
Old May 4, 2006 | 01:30 PM
Josh2006's Avatar
i suppose if i were to do it again i would do SFC first mainly cuz we have verts,the primary reason i got the SFC is cuz i installed 3.73 gears so, and yes i love my springs and they make my car look 10x better and no complaints about the ride and the ability to launch harder but its not that expensive to do so its all in whats important
-Josh
Old May 4, 2006 | 02:47 PM
Roadhouse's Avatar
YEP! They were around 400 bucks
Old May 4, 2006 | 08:27 PM
bboyferal's Avatar
I have all my suspension done (SFC, LCA's, PH Rod, TQ Arm, etc.).
I did springs first and it wasn't the end of the world. I say do them first as long as it's not over an inch and a half drop. It'll look really nice.
Old May 5, 2006 | 07:47 AM
gyrene2003's Avatar
what about if im runin stock rims with 255s on them, will i need to do anything special, and also im just lookin for a mild drop, nothin crazy, just want to get rid of the wheel gap!
Old May 5, 2006 | 10:43 AM
bboyferal's Avatar
I'm running 275 40 17's on 17 X 9.5's. Dropped 1 inch... Works just fine.
Old May 5, 2006 | 12:49 PM
gyrene2003's Avatar
what springs did u use for the 1" drop?
Old May 5, 2006 | 01:07 PM
FERNANDO's Avatar
Default Sfc
I just ordered a set of bolt on sfc's from don goetz at chirpthird.com. i think he makes them. they are powder coated and under $300. all the other companies charge way more for vert bolt ons and do not ship to military apo addresses, they don't get my money. the buyers say great things about his sfc's. the link below is what they look like. i also got his stb.
http://www.chirpthird.com/vb/showthr...ighlight=GOETZ
Old May 5, 2006 | 02:05 PM
bboyferal's Avatar
BMR's.
Old May 7, 2006 | 05:12 PM
GR8RYD's Avatar
In the interest of full disclosure, I need to say I probably will never drop my WS6. I would like to keep it as stock as I can. I did add SFCs and a STB just to keep it from shaking itself to death on our exciting (read bad pavement) Texas roads. I failed to install those on my 91 Z28 5M convertible and I deeply regret not doing it. I was not looking for a significant improvement in handling; I just wanted to keep her screws, etc. tight as long as possible.
Old May 7, 2006 | 06:28 PM
bboyferal's Avatar
My car looks stock to me... Wheel gap is not a "stock" attribute most people say they would like to keep.
When I dropped my car 1 inch, my wife says I wasted my time because she could not notice the difference. Obviously, she's not the best example of an enthusiast observer, but you get the point.
Old May 7, 2006 | 07:15 PM
Honda Hunter's Avatar
I didnt feel squat with my subframe connectors and if you do some searches youll understand why they shouldnt be a first mod and arent really needed for a while. Money could be better spent elsewhere.
Old May 7, 2006 | 08:53 PM
bboyferal's Avatar
100%
