Convertible Vehicles Enthusiasts | Information | Maintenance
m6 vert crossmember
Old Jun 20, 2006 | 08:28 PM
z28convert's Avatar
Default m6 vert crossmember
swapping from a3-m6 and was wondering if convertibles use a different tranny crossmember than hardtops and t-tops? tried the search and came up with nothing
Old Jun 21, 2006 | 05:26 AM
z28convert's Avatar
ttt...
Old Jun 21, 2006 | 12:10 PM
Kewl_Blades's Avatar
From what I researched, no...no difference.
Take a peek at some of the aftermarket tranny mounts and crossmembers. No designation that it will not fit verts or visa-vera. But look at the subframe connectors...there is a difference.
Old Jun 21, 2006 | 12:28 PM
Honda Hunter's Avatar
Good question. From what Ive seen theyre the same.
Old Jun 21, 2006 | 04:07 PM
z28convert's Avatar
i called gm and they said the part numbers were different and they looked they they were different.
Old Jun 21, 2006 | 04:38 PM
intresting..
Old Jun 21, 2006 | 06:02 PM
93TAWicked1's Avatar
I'm in the middle of one right now. The crossmember itself are the same the shield brace thingy is quite a bit different, but I'm pretty sure you just use the same one as the A4 came through like the driveshaft, and tranny mount they are the same for A4 and M6.
Hope that helps!
Old Jun 22, 2006 | 05:34 AM
z28convert's Avatar
thanks for the info guys
