Convertible Vehicles Enthusiasts | Information | Maintenance
How to properly lower and Raise top?
Old Jul 29, 2007 | 04:26 PM
TransAmBand1t's Avatar
Default How to properly lower and Raise top?
Please forgive my n00bie-ness. My name is Sam, I am 17 years old and I have been in love with Third Gens for the past few years. I sold my 92 Camaro Rs a few weeks ago and I just picked up a 95 T/A 'Vert for a deal I couldnt pass up. I'm fairly new to the 4th gen world. I know enough to get by...
However, I just want to know how to properly lower and raise the top. Lowering it is pretty straight forward to me. I just open the latches and press the button and its down. However, I am having problems bringing it up. When I push the button to bring it up, it just goes up a little and gets stuck. I have to end up Pulling on the top as I am raising it. Then when it's up half way I have to manually finish the process. Something tells me thats abnormal... What may be the problem?
Thanks,
Sam
Old Jul 29, 2007 | 04:29 PM
CrawlinWS6's Avatar
Import Patrol
Sounds like it's the top motor.
Old Jul 29, 2007 | 06:31 PM
SScott's Avatar
What he said.
Old Jul 29, 2007 | 09:08 PM
Exactly what I didnt wanna hear. I thought I might have to bleed the system or something... =(
Old Jul 30, 2007 | 06:55 AM
JohnnyBs98WS6Rag's Avatar
Check the fluid level first, probably just low and as a result you got some air in the lines. Bring it up to level, cycle it a few times (that's all you do to "bleed" it of air), then recheck / add fluid as required.
Old Jul 30, 2007 | 10:01 AM
waldo's Avatar
check the fluid level, I may be low.
Old Jul 30, 2007 | 10:47 AM
quiet_storm98's Avatar
mine was doing the same thing and then i added fluid and it has been fine ever since
Old Jul 30, 2007 | 11:54 AM
Thanks guys! I'll def do that this week.
Old Jul 30, 2007 | 12:15 PM
99'CajunFirehawk157's Avatar
Cool Welcome
I wish I had a T-Top.
You need to change your sig now....
Old Jul 30, 2007 | 04:14 PM
lol, The car is too much comb for me. I might end up selling the car to my dad and go out and get back in a Third Gen.
On another note, I'm assuming to properly bring the top up, you just push the button and it comes up then latch it, right?
Old Jul 30, 2007 | 09:20 PM
Yep, nothing to it...
Old Aug 1, 2007 | 01:52 PM
Jer4251's Avatar
Not mine... on my 96 I have to raise my hand up and make sure my flip rod isnt in the way, it was in 2 pieces when i got the car and it sometimes gets in the way, it snapped right at the little circle in the rod. and when i lower the top i have to make sure the 2nd bow is back enough to sit flat.
anyone know where to get a flip rod from?
they must break a lot cause my 91 rs vert has 2 missing
Old Aug 25, 2007 | 05:42 PM
So I went and bought a quart of Hydraulic fluid. I added some, then put the top up and down a few times and kept filling it. Is there a mark where I should have the fliud? I filled the fluid until the top mark. Is that alright?
Oh and another thing, after I put fluid in, I noticed there was a fluid leak behind the left rear wheel. Im hoping that's the fluid I spilled.
Thanks!
Old Aug 25, 2007 | 07:53 PM
bboyferal's Avatar
Sounds like what it might be... Keep an eye on the level from time to time to be sure.
Old Aug 26, 2007 | 01:32 AM
I came back home a hour ago and rechecked the fliud level, it's the same level I left it. I'm relieved. Thanks!
