Convertible Vehicles Enthusiasts | Information | Maintenance
Vert problems
Old Jan 9, 2008 | 10:39 AM
ConvBird's Avatar
Default Vert problems
bought a 97 t/a vert with inoperable top - no action or sound when top button is pushed - works ok manually - any ideas where to start??????
Old Jan 9, 2008 | 11:44 AM
Xsta Z 28's Avatar
The pump in the trunk? . . . left hand side, under a little trap door in the carpet.
Old Jan 9, 2008 | 12:33 PM
JohnnyBs98WS6Rag's Avatar
If no sound when button is pushed, could be either bad pump motor, blown fuse, bad switch, or bad wiring / connection. Check the fuse first. If not that, disconnect wire harness at motor and check for voltage in both directions (while someone presses switch up/down). If you have power there, then the motor is likely bad. If no power, then the switch is next place to look.
Old Jan 9, 2008 | 02:37 PM
ConvBird's Avatar
Thanks..... any thoughts on best place to buy a replacement motor ?
Old Jan 9, 2008 | 05:18 PM
whaler1582's Avatar
try checking the little black **** on top of the pump. if you turn that **** you can either have it as a power top or a manual top. if that doesn't work, the motor is probably bad.
Josh
Old Jan 27, 2008 | 06:54 PM
softtop95ta's Avatar
Default try this to
three years ago mine slowed down then just stopped working because it was low on fluid i refilled the reservoir and bled it out i have had no problems since
