Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Just finished the car! What will it run in the 1/4?
Old 11-26-2008, 11:15 PM
AZNastyz06's Avatar
Default Just finished the car! What will it run in the 1/4?
i am guessing in the 10's on my slicks!
With timing pulled we did 428.42 h/p! So we estimate 440-445 with timing put it! WOW this with stock heads!
With Nos 100shot we made 525.33 h/p and 553.67 lb torque!
Old 11-27-2008, 12:05 AM
SlwSVT's Avatar
What mods you got on motor? I would guess 120-123mph on motor and depending if you use the juice off the line and hook, could be a 10 second run.
Old 11-27-2008, 08:09 AM
usenterprise's Avatar
my guess 10.8 at 130. with a 1.65 60ft. keep us posted. good luck
Old 11-27-2008, 09:36 AM
blk04z's Avatar
I went 10.55@130 cam only with a 100 shot. Car put down 420/389 NA
Old 11-27-2008, 10:30 AM
AZNastyz06's Avatar
were you at Atco?
Old 11-27-2008, 12:16 PM
blk04z's Avatar
No it was at E-town raceway park
Old 11-27-2008, 01:16 PM
AZNastyz06's Avatar
what are your launch techniques?
Old 11-27-2008, 03:46 PM
blk04z's Avatar
5500 rpm launch pretty much dumping the clutch. Running 26x11.5 et street.
Car has more in it. Could probably run high 10.4xx's with the 100 but im uping the shot.
Old 12-08-2008, 01:14 AM
noobc6owner's Avatar
Default damn
good run
Old 12-08-2008, 02:15 AM
sultan(ZR-1)KSA's Avatar
take care of your rear end my frind this is a vette
Old 12-08-2008, 08:54 AM
Heavy H.P.'s Avatar
Those are some good numbers bad boy is going to hall ***.
Old 12-08-2008, 10:24 AM
Restricted User
juicdta's Avatar
this makes a big difference. that is one of the if not the best track in the country w/ awesome DA and always is known for it's killer track prep.
Old 12-08-2008, 04:18 PM
Next Phase's Avatar
It all comes down to your 60' time....
With a 1.7/1.8 you will be in the 10's...
Old 12-08-2008, 04:43 PM
alwaysinboost's Avatar
going to be very driver dependent. with a decent launch, and if you spray all gears, 10's shouldn't be a problem. Post back your results when you get it to the track.
Old 12-08-2008, 06:05 PM
blk04z's Avatar
Track prep does help. If you cant hook obviously your time will suck. Post up when you get to the track. Good luck
Old 12-08-2008, 09:25 PM
AZNastyz06's Avatar
ok went to the track and had some success! Ran out of Nitrous pressure during my only run on Nos and landed 11.1 @124. With using the nitrous on the dyno and a few test runs i ran her low and did not refill prior to going to the track!
I did run a 11.67 @118 on motor and an 11.46 @122 on motor!
Old 12-08-2008, 10:37 PM
SlwSVT's Avatar
122 with 430rwhp is damn good. Congrats should be an easy 130 trap with the juice.
Old 12-09-2008, 08:56 AM
Heavy H.P.'s Avatar
Dam good run when are u going back to the track?
Old 12-09-2008, 05:10 PM
blk04z's Avatar
Your trap speed is there. My best NA pass was a 11.1 @ 123. Like stated above your trap speed on a full bottle should be around 130.
Old 12-09-2008, 06:41 PM
SERB Z06's Avatar
did you get booted for no cage or do you have a roll bar?
