Nitto or Toyo?
Front: $258/each
Rear: $348/each
I can get Nitto Invo's on Discount Tire for:
Front: $165/each
Rear: $271/each
But my shop (since I'm not buying them from him) would have to charge about $30/each to have them mounted and balanced and old tires thrown away.
What should I go with? It's around a 700rwhp car, so I don't expect the rears to last very long...
Now Ill be back off to the dyno to get a full dyno pull and see what MY lil car will finally put down, as I was only able to take it up to 5800 rpms due to breaking loose on the dyno at only 7.5#...
Of the two, I'd definitely recommend the Invos. If you are more concerned with road course and dry traction, also take a good hard look at the Nitto NT-05s. Those will probably be my next tire, but I did already get caught in a recent downpour on the Invos, and they held wet traction pretty good.
NItto and Toyo are made in the same Factory!
again, I don't want to spend a lot of coin as I'll smoke the rears off
I think the RA1's are the ****. You cannot compair the INVO and the RA1 together. The RA1 is serious traction. Invo,..made if your sub 500 or less. They look cool.
R888's are badass.....although more expensive The RA1's are more then enough.
I agree with V-Series, I really like the RA1....I drive a C63 with R888s alot and they are amazing but they didn't last very long. The side wall so super thick. Go with RA1's....
