who is in the 10's NA with stock bottom end c5's??
i plan to find a c5(97-04) in the 12-15k range with bolt on's and do my h/c/i setup. mileage doesnt really bother me because 1.i have a 190k stock bottom end in the 10's and it has been for a while. and 2. i can get 370's for about 750$
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
thanks for all the feedback guys
looking to jump into c5 (frc,coupe,z06) and looking to see how many people are getting into the 10's NA and whats all done to the car.
im looking to run the following to get mine there
LG cam in the upper 230's lower 240's
Prc 215's,afr 205's,dart 205's??
342-390's
full bolt on's
Fast 92 ported
3600-4000 Cirlce D or heavy duty clutch!
ccw drag pack
Driver mod
anything else???
if you could provide the following information that would be great!
type of heads
cam
Intake?
gears
rear end
size converter other wise standard
ive looked for a thread to answer my questions but couldnt find one.
342-390's
full bolt on's
Fast 92 ported
ccw drag pack
Driver mod
anything else???
type of heads
cam
Intake?
gears
rear end
Ive gone 11.3@126 on motor in my car and 10.50@136 with a 100 shot of nitrous. I was on my homemade drag pack (GTO spares up front and CCWs in the rear with Hoosier Drags) Here is my list of mods:
Cartek LS6 Stage 4X heads. Includes, full porting heads intake, exhaust, and combustion chamber, Manley severe duty stainless valves, 2.02 intake, 1.57 exhaust, seals, Manley dual springs, spring seats, seals, titanium retainers, milled .030.
Custom grind Cartek Stage 2X Cam computer verified.
228-232 582-598 116LSA
Cromoly hardened push rods.
Cometic heavy duty head gaskets.
ASP under drive pulley with belts.
Roll master dual roller timing chain.
Ported Z06 oil pump setup for the roll master.
FAST 3 piece intake manifold ported to 4X with a 90MM throttle opening.
Ported LS2 throttle body.
ECU Reprogram 97-2004 LS1 full dyno tune by Lethal Performance
Notch pistons for clearance.
Complete NX system includes, NX wet kit with 10# bottle, purge, MSD digital RPM window switch, timing retard module, custom switch panel with micro switches and LED lights, all wires, Bosch relays. Also includes, blow down tube, full throttle switch, Kenny Bell Boost-a-pump, and NGK BR7EF spark plugs.
Nitrous Outlets 860 Fully automated aluminum bottle heater
4.10 gears.
C5 passenger and driver side 300M output shaft with side gear.
C5 line lock kit includes pre-bent line with braided flex hose, inline line lock solenoid, and switch installed.
Vararam B2 intake
Vararam Power duct
GM Racing spark plug wires and NGK BR7EF plugs
160* thermostat
New Coolant crossover
CCA Red oil catch can
American Racing Headers (1 7/8 primaries 3" collector)
American Racing 3" X pipe
Borla Stinger 2.5" catback
Built T56 tranny by Lethal Performance
Hurst C6 short throw shifter
Spec III Clutch and Billet aluminum flywheel
Brand new Slave cylinder
Upgraded Tick Performance Master cylinder
Innovate LC1 Wideband
Cross drilled and slotted rotors on all four corners
Ceramic brake pads recently installed
Painted brake calipers.
CCW Big street Classics
275-40-18 Michelin Pilot Sports in the front (still brand new)
335-30-18 Nitto 555R Drag radials in the rear (almost out the door)
Tinted windows all around
4.10 gears.
Vararam B2 intake
Vararam Power duct
160* thermostat
I just went 10s NA stock bottom 6sp only left at 4000 slipping the cluch out went 10.93 at 128 with a 1.63 60ft
Trick Flow 215s
Custom Cam
ARH 1 7/8 Headers
RPM drivetrain
Spec twin disk
FAST intake
usual boltons tuned by me
Trick Flow 215s
Custom Cam
ARH 1 7/8 Headers
RPM drivetrain
Spec twin disk
FAST intake
6600 rpm clutch dump of death Administrator
