who is in the 10's NA with stock bottom end c5's??
looking to jump into c5 (frc,coupe,z06) and looking to see how many people are getting into the 10's NA and whats all done to the car.
im looking to run the following to get mine there
LG cam in the upper 230's lower 240's
Prc 215's,afr 205's,dart 205's??
342-390's
full bolt on's
Fast 92 ported
3600-4000 Cirlce D or heavy duty clutch!
ccw drag pack
Driver mod
anything else???
if you could provide the following information that would be great!
type of heads
cam
Intake?
gears
rear end
size converter other wise standard
ive looked for a thread to answer my questions but couldnt find one.
342-390's
full bolt on's
Fast 92 ported
ccw drag pack
Driver mod
anything else???
type of heads
cam
Intake?
gears
rear end
It can be done, but not easy. With good air no problem with a nasty heads/cam, ported fast and stock gears. Fastest bolt on C5 is 10.89 @ 126, but in great -DA air. Great air is everything. Where I live we don't have it.
I agree where you live that air quality makes it difficult, but at this day and age of LSx performance it's certainly not impossible or even hard to do for that matter. I cant remember how many 10 second NA cars we have out there, let alone tons of other shops as well, it's common place now IMO.
would it be easier to get in the 10's with an a4 or m6? and also how strong are these rear ends? what kind of 60's can i get in before i haft to get a different rear end? i dont see much guys mentioning anything about swapping rear ends or building them.
Easier with a auto. The rear end is a toss up, some hold some don't. You will for sure want to upgrade the half shafts to a DTE set up. That is what I have in mine. Build the rear when you have to.
I have a fairly aggressive Heads and cam setup and aftermarket drivetrain and an aggressive clutch...even the aftermarket drivetrain stuff breaks...save yourself a headache and do an auto....FWIW the FRC's only came in 6sp so you'll have to do a coupe or do an auto coversion if you choose to go that route
TSP PRC LS6 Stage 1 $999 heads bolted on no modifications
TSP MS3 cam installed straight up
Fast 90mm ported
4.10 built rear
Textralia 0Z700 clutch
ET streets 26x11.5x16/skinnies in front weld draglite package one off's
removed passenger seat
great air,great track,near sea level
10.81 at 130mph drove 1.5hr to the track and back A/C/ heat everything there and intact.
what do you guys think about an l92 setup... would it be easier to get in the 10's with a good set of l92's and a fast lsxr intake and one of our sponsors? or maybe a custom spec cam.
HD Axles –
These HD axles were developed with serious hp in mind! These axles Include larger diameter 300M axle bars (increased from 1.125" to 1.375"), larger 33 spline outer CV (increased from 30 spline), and hubs (with bearing) to accommodate the larger outer spline. This kit also uses our 108mm Porsche-style inner CV joints with our chromoly bolt-on inner flanges. In order to achieve optimum strength, we have increased the diameter of the seal surface on the bolt-on inner flanges and include new axle seals to accommodate them. Rated to 1000HP with a 1-year warranty. Also available are the new direct replacement 300M differential spline output shafts, also with a 1-year warranty.
Price $2299.00
