straightline performance rear mount turbo 408 cui build
a few little details on the car 408 cui, trickflow heads, custom camshaft, je forged pistons, eagle forged rotating assembly, rpm lvl 6 trans with yank 3600 converter, rpm lvl 3 diff with quaife.
now to the build my goal is to make 700 rwhp but the way things seem we may make more. the heads had to be sent off to open up the chambers to get us to a boost friendly 8.8:1 we were at a 11.1 before.
turbo specs
here you go guys, specs on the turbo
Compressor wheel - 80.31mm/109.73mm 120lbs/min
Turbine wheel - 98mm/88mm
Compressor inlet - 5.5" hose
Compressor outlet - 3" hose
Turbine Inlet - Divided TV91 (T6)
Turbine Outlet - 5.5" v band
TV Turbine Housing A/R - 1.32 A/R
and on with some pics the car before the start of tear down
![](http://i91.photobucket.com/albums/k308/vettandtyphoon/vet1.jpg)
![](http://i91.photobucket.com/albums/k308/vettandtyphoon/vett-1.jpg)
after tear down
![](http://i91.photobucket.com/albums/k308/vettandtyphoon/vebg.jpg)
![](http://i91.photobucket.com/albums/k308/vettandtyphoon/vetttt.jpg)
![](http://i91.photobucket.com/albums/k308/vettandtyphoon/vettttttttt.jpg)
![](http://i91.photobucket.com/albums/k308/vettandtyphoon/tr23.jpg)
![](http://i91.photobucket.com/albums/k308/vettandtyphoon/tr1.jpg)
![](http://i91.photobucket.com/albums/k308/vettandtyphoon/tr.jpg)
turbo specs
after tear down
![](http://i91.photobucket.com/albums/k308/vettandtyphoon/dfdftrb.jpg)
