Hatch or FRC?
Here's my reasons for going FRC:
A) Looks better
B) It's lighter
C) The Z06 comes as FRC only
D) Lots of trunk space with a trunk lid. Nobody sees what's in my trunk (and that's good!)
The only draw back is the lack of a targa top. But I have access to my dad's 03 Vert if I wanted a top-down situation going on.
I like the looks of the hard top cars the best. Seems more like the cockpit of a jet to me
If you really want to know more about this, please do a search on this on CF. To set the record straight, the Z06's top speed is purely limited by gearing in 5th gear. Neither cars make enough power (stock) to push higher speeds in 6th gear, nor should you if you made enough power since 6th gear is rather weak. The top speed of the Z06 is 172MPH. The top speed of the coupe is 178MPH. In theory, if the coupe had enough power, it would actually go to 182MPH in 5th. If the you put an MN6 (instead of an MN12) trans into the Z06, the Z06 WOULD push to 182MPH. For those of you that have stock coupes that have seen speeds higher than 178MPH, please get your speedo checked.
FRCs were optioned with the HUD. I know that the 2000 FRC was for sure. I believe the 99 was as well although I could be mistaken on that.
If it's nice I take my '07 vert out.
Bob K.
Really which one do you like the looks of better? The small differences aren't anything to lose sleep over.
If you really want an open you can do the targa top mod which looks pretty bad a$$ on a hardtop.
The FRC is devalued enough where I can have a cage put in, turn up the boost, and not have to worry about residual value.
