ST80 347ci dyno number on 10psi !!!!
What's up guys!!!
I finally had the time to dyno my car too bad the whether was almost 100F
01 C5 ZO6
Engine/transmission
Built 347ci 9:1 comp
Brutespeed cam 232/240 595/608 115
stock untouched 241 heads.
All valvetrains.
stock intake and tb.
RAM Carbon twin disc clutch / aluminum flywheel.
RPM T56 trans / stock rear 3.42
Turbo setup:
Custom build ST80 Turbo kit 1.15A/R
3.5' Downpipe going to STOCK TI EXHAUST for now.
Percision WG
Tial BOV.
Fuel:
RSI Fuel pump hanger (great product)
DW pumps.
Fast rails.
83lbs Injectors.
Aeromotive fuel pressuer.
Cooling:
Dewitt Radiator.
Hypertech thermostat.
stock water pump.
also waiting for the dewitt bigger fans..
and some suspention/brakes/show parts here and there
couple of pics
on 10psi made 598rwhp 549rwtq SAE with very safe 10:7 A/F Ratio, 15timing.
91octane, 98F whether Running heavy 360Forged 19×12 in the back...
The car spools extremley fast on the street and drives awesome I'll post some dyno/street vids very soon (needs some better tires though) ..
Waiting for the boost controller to arriver then we'll turn it to 14-16psi.
Even though I wanted 600-630rwhp on 10psi I'm still very happy with the numbers with the safe tune , whether and stock catback...
Do you guys think it's possible to get 700-750rwhp on 14-16psi??
Hopefully we'll find out in the next two weeks..
Let me know what you guys think?
Sam
01 C5 ZO6
Engine/transmission
All valvetrains.
Turbo setup:
Percision WG
Tial BOV.
Fuel:
DW pumps.
Fast rails.
83lbs Injectors.
Cooling:
Dewitt Radiator.
stock water pump.
couple of pics
Sam
The math is pretty simple as far as break horse power. The crude number is that you'd get about 100% your N/A power for every 1 bar (~14.5PSI) of boost. You'd need about 830 BHP to make 700 RWHP. So your motor would in theory have to make 415 BHP without boost to make 830 BHP at 14.5 PSI.
So, yes, I'd say you should be able to hit your goal with about 15-16 PSI.
Thanks.
I Dynoed the car before the turbo with stock headers/heads/intake and tb.
very rich tune the car made 379rwhp 9:1 comp I think thats close to 440 BHP
I guese will find out in the next two weeks about the numbers
Still not nice enough for me I need to turn it up
But the damn stock 241 heads are killing it ..
Thanks.
That sounds about right. I think you'll hit your goal around 15 PSI.
I'm a little iffy about the 15% loss rule with a manual transmission when it comes to Corvettes. I think even though Corvettes have IRS, the loss is closer to 13%. Either way, your 440 BHP sounds about right and you'll probably see about 840-870 BHP at 1 bar.
You're not on 241 heads, are you? Your car should have come with 243s since it's a Z06.
Thanks man..
I agree I always thought the Vette IRS have 12-13% loss.
I sold my 243 heads long long time ago I had MTI 317 III Heads but I also sold them looking for aftermarket casting heads
Thanks.
