thinking about a vararm. opinions please
TIA
thanks for the reply.
P/M with your opinions of the MTI cam only setup.
TIA
better than the blackwing, I don't have the carbon fiber top so I can't
comment on that, it is time consuming to install, about 4-5 hours.
Read the instrucs. Rain water is not a problem, just don't go thru
standing water that is as high as the fog lambs. It is worth the
money, hope this helps.
If it is a non-Z06, pull the covers down by the foglights and let air in there, and you are set.
got it a coupla weeks ago and installed it myself. took about three hours to do the whole thing. drove the car afterwords and after a coupla hickups the computer recognized better airflow, and loved it. you can definately feel the difference, almost immediately.
I highly recommend it. if anyone else is thinking of upgrading their airfilter I would say get the vararam. stick your hand out the window at 60 or 80 mph and imagine that force pushing air into your engine. need I say more?
I got mine from exit28motorsports. $315.00 shipped. go for it.
When I first started working on cars, we used to pour water down the intake to help remove carbon. Unless you're fording a river you wont have any problems with water.
My issue with the vararam, and the reason I replaced it, is that the filter doesnt hardly filter, and is very difficult to make seal around the edges. Every time I removed it I found a fine layer of dust after the filter, and usually I could find a dirty spot on the edge where the air was passing around the outside of the filter.
