Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
P0700 and P0716 C6 Corvette A6
Old Aug 18, 2013 | 07:25 PM
fastenough's Avatar
Default P0700 and P0716 C6 Corvette A6
Anyone else received these codes? Car is bone stock with 19k miles on it. I cleared them once and they take about 2-3 weeks to come back. Normally they come back when I am sitting at light. I feel a slight bump and then CEL showing these codes.
Any help would be appreciated as I have looked all over with very little luck. My only idea is to replace the VSS at this point since I found a thread that said that was successful in clearing this up.
Old Aug 19, 2013 | 08:05 AM
Larry's Avatar
http://www.obdii.com/codes.asp
Old Aug 19, 2013 | 11:53 AM
fastenough's Avatar
Thanks. I figured out what the codes were but I am more so looking to see how people were able to fix them. I have seen everything recommended from replacing the VSS, the trans, bad grounds etc.
Old Apr 2, 2014 | 06:41 PM
fastenough's Avatar
So this code comes back every 1500 to 2000 miles. It's really strange. I did a bunch of searching and others have had this problem but no one has posted a fix. It looks like the simplest option is replacing the input speed sensor. Unfortunately this requires removing the valve body but it's a good first place to start. The sensor is $20-40 depending on where you get it. I guess I'll order the part and go from there. It also looks like there is a special tool required to take the valve body out.
Old Apr 2, 2014 | 06:53 PM
fastenough's Avatar
http://www.camaro5.com/forums/showth...=160511&page=2
This thread mentions a Camaro with the same issue. He cleared it. Car drove fine then it came back. The dealer replaced the sensor and it corrected the issue.
Old May 22, 2014 | 12:17 PM
fastenough's Avatar
I figured I would update this now that I have installed the new sensor. All is well. The install was kind of a pain with removing the pan. There are one or two bolts that are hard to get at. Otherwise its pretty straight forward. I used AllData to guide me through the process though.
Old Oct 5, 2020 | 07:26 AM
pjs's Avatar
pjs
Thanks for the update! I just hit these same codes on my 09 C6 Corvette A6 with A&A kit+meth....If stock cars are hitting this then maybe it's not just because of the extra power, I'm hoping anyway...
I've cleared the codes and waiting to see if they come back.
I hear the sensor is on top of the diff? If so, the trans needs to be dropped down?
Thanks,
Pj
Old May 2, 2021 | 04:31 PM
Waylon Glasscock's Avatar
Default Similar happening to me
the same codes have happened to me 2 times now. Both times I noticed that my temp had just passed 220 stuck in traffic. Being stuck under 2k until I turn it off, disconnecting battery has fixed it until I get stuck in the Texas heat again. do you know which sensor they needed to replace to fix it?
Thanks,
Pj
Old May 2, 2021 | 06:25 PM
pjs's Avatar
pjs
Seems to be the VSS. I've been lucky so far; I changed the trans fluid and filter, cleared the code, and hasn't com back yet.
Maybe someone else can chime in. Good luck.
Pj
