C5 front suspension help needed
Here is a good thread on how someone made up there own stuff to measure trim height.
http://www.corvetteforum.com/forums/...pension-2.html
Check out post #32 - unfortunately the pictures are gone, but it may explain things a little better.
From the center to the rear mounting bolt of the UCA to the center of the rear mounting bolt of the LCA I got 10 3/8".
That was with a laser level that has about a 1/16" thick beam so I would say give or take 1/16".
That was on a C6 though.
Another thing I measured not sure if it's of interest or not are the angles of the mounting points of the A-arms when looking at the car from the side. For the UCA it was 6.5 degrees and for the LCA it was 2.5 degrees.
This car will be mainly a street machine so road racing specs work.
When you say mounting point angle you mean the rear side mounting bolt is higher than the front side mounting bolt on the UCA and LCA? Is it like this factory? I guess I was under the impression the mounting points were parallel to the ground?
This picture illustrates better than I can describe.
So from the numbers above the front UCA is at a 6.5 degree angle and the LCA is at a 2.5 degree angle from what I measured on the C6.
Here's another picture that shows the upper arm at an angle, this would be the RF corner of the car.
