How much labor to get oil pan replaced.
Well put new motor in the Vette and while it seems to be running great I have a problem Oil is coming out from where the sensor by the oil filter is. I already have a new pan and such anyone know install costs average numbers. I could do it but don't feel like pulling motor again when shop can drop cradle and pull and replace pan in like 2 days. Any ideas about Install cost only.
Thanks
Thanks
Ckeck the two 10mm bolts were the sensor goes into, it's seperate from the pan. There's a o-ring gasket there that sometimes leaks or is not tight, also cleaan off around sensor, may need to put thread sealer arouns sensor threads. Thougtht I would give you an idea before your time repacing pan over a 50 cent repair. Torque on the 10mm bolts is 89 inlbs/7ftlbs(not very tight)good luck.
