Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Headlight Gear 3d Printed
Old May 5, 2021 | 05:45 PM
Woodylyf767's Avatar
Default Headlight Gear 3d Printed
Someone will use this. I used 80% infill PLA and printed at a 45 deg angle. I do not recommend printing at a 45 degree angle. Print it flat it shrinks more evenly. This gear eliminates the vibration damper and needs to be used with the provided spacer.
https://grabcad.com/library/c5-corve...adlight-gear-2
I'm sure yall are ballers and don't need this budget fix but as the prices of these cars fall there may be someone else out there looking to not spend 50$ for a new brass gear and/or not wanting to wait for shipping for the 25$ Nylon replacement/rebuild kit. Mine works by the way. I only have 20 cycles on it so far. Seems to work better as it is broken in.
Not exciting I know
Old May 5, 2021 | 05:56 PM
JimTA's Avatar
Excellent work and I would love to have a copy.. but link doesn't work...
Old May 5, 2021 | 06:25 PM
So the link works on this computer but none of my other computers. I am guessing it is because I just made the GrabCAD account and it either takes a while to get posted, or they have to view it to make sure it isn't something illegal. That's my guess.
https://drive.google.com/drive/folde...36?usp=sharing
See if this works
Thank you for letting me know
Old May 5, 2021 | 06:28 PM
JimTA's Avatar
that worked great.. thanks much!
Old Nov 20, 2023 | 02:42 PM
swooby's Avatar
Looks good, just wonder how long it will last.
Old Nov 21, 2023 | 12:55 AM
sjsingle1's Avatar
do the birds use the same gear ?
Old Nov 21, 2023 | 12:03 PM
So I actually initially 3d printed it to last as long as the new one was coming in the mail. Welp, I got the new one in the mail and since this one was working I didn't swap it until it failed
I printed it at a 45 degree angle so it wouldn't be weak amongst the layer lines but the problem with this is it expended/shrunk non uniformly. It was tight on one side and loose on the other
It wound up working for 2 to 3 months before I swapped the one I got in the mail. If you print with it flat I would imagine you would have it last longer than that.
Old Apr 21, 2024 | 08:08 PM
lucianp's Avatar
Thank you for the model!
I printed this on a Bambulab P1S with PETG at 100% infill. Hoping that PETG is strong enough to last, will update if it breaks.
If it fails again I will try with a stronger nylon filament and update if it works! So far, the gear is working and has fixed my headlight
Old Apr 22, 2024 | 11:43 AM
Love to see it!! 3d printing is great for keeping these guys functioning nice
Glad you got some use out of it. Please do keep us posted
