Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
rear end question?
Old Nov 15, 2004 | 06:42 PM
slow6.0's Avatar
Default rear end question?
i was wondering how much power will a stock rear end take in a c5 car. Also going mid to low 10's in a targa top car would i need to cage it or would i be able to stiffen it up enough with a backbone plate? As you can probably tell i dont know much about the cars other than the motors, so really any suggestions on what is good and what is bad about them would be very helpful
Old Nov 15, 2004 | 06:51 PM
Oscar Will's Avatar
Most sanctioning bodies (i.e. NHRA) will require you to cage it up if capable of 10 s. You might as well back half the thing and run 4-link and a decent diff., that stock axle and suspension isn't going to get the job done with the kind of power it takes to run that quick.
Old Nov 16, 2004 | 06:41 AM
J-Rod's Avatar
6600 rpm clutch dump of death Administrator
I've run mid 10's in a H/C car. We've just broken the first rear in the car. I launch at 6600 and cut 1.42 60' times. There are cars that run mid to low 10's on the stock rear. The torque tube usually goes before the rear. Just make sure you have upgraded the shaft(s) in the rear.
Old Nov 16, 2004 | 06:08 PM
slow6.0's Avatar
what kind of suspension mods have you done to your car?
Old Nov 16, 2004 | 07:03 PM
98UltraZ's Avatar
In terms of suspension, check out http://www.dynotech-eng.com/
They are an EXCELLENT company, that I have had good dealings with! They make upgraded rearends, and other parts. I would get their differential brace, and their rearend setup. Those would be the most beneficial to keeping the rear in one piece. http://www.dynotech-eng.com/dte_c5_diff_strut.htm
J-Rod is correct the torque tube is also another weak link in these cars.
Old Nov 16, 2004 | 10:34 PM
fast 98 C5's Avatar
I have been doing 10's on the stock rear end for a couple of years with a A4.
Old Nov 16, 2004 | 11:14 PM
pdd's Avatar
pdd
i blew my DTE rear after 2 runs ever at the track with a hardended rear output shaft
Old Nov 17, 2004 | 06:17 PM
slow6.0's Avatar
ok what is an A4 car. i have seen a lot of guys refering to their cars as tht but what does it mean?
Old Nov 17, 2004 | 07:22 PM
J-Rod's Avatar
M6 - manual 6 spd
a4 - automatic 4 speed
You will see m12 every once in awhile that is a Z06 m6 (it has a different set of gears inside lower 1st and 2nd but it is still a 6 speed)
Old Nov 17, 2004 | 07:23 PM
J-Rod's Avatar
None. The car is all stock as far as suspension goes. It now has a DTE brace and an LAPD tunnel plate, but suspension wise it is stock.
Old Nov 17, 2004 | 07:58 PM
slo-vette's Avatar
Like the other guys have said, you will need upgraded output shaft(s). Guys with the DTE brace, would you spend the money again on it?
Old Nov 18, 2004 | 08:47 PM
U LUZ's Avatar
yes i would in a heart beat i have one on my car ....thank you j-rod for telling me where to get it by the way.....but i think it stiffens everything up....
Old Nov 21, 2004 | 11:26 AM
REDGAR's Avatar
You will need a rollbar 5 or 6 point at 11.49. Roll cage 12 pionts, will be needed at 9.99
The rears
