Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Ran my 04 Magnacharged Coupe this past weekend.
Old 03-28-2005 | 05:30 PM
Qwik03's Avatar
Livin La Vida Goat
Default Ran my 04 Magnacharged Coupe this past weekend.
The car is currently making 440rwhp and 430 rwtq
It has Magnaflow Exhaust and a box stock I/C Magnacharger set-up.(No tuning or pulley swap) Other than that the car is as delivered from Chevrolet.
I took it to a private track day out at Fontana this past friday and was pleased with the times.
I ran it with 1/2 tank of gas with zero weight reduction.
1,000 ft DA
There was a 10-15 mph headwind most of the night.
First two passes were on street tires:
12.52/12.59@118.5 (2.15 60ft on Run craps) the car would get scary on the 1-2 shift I had to lift to avoid the center line.(2 vipers lost it earlier and crashed so track prep wasn't amazing)
I said screw that and put on some 17" ET Streets mounted on ZR1's.
First pass with a minor burnout and a 2,000 rpm launch netted me a 11.95@119.2 (1.89 60ft)
I then decided to get a little more agressive.I lowerd the tire pressure to 14psi and did a nice burn-out.II then launched at 3,500 rpm's and cut a 1.71 60ft!Went for second gear and it just wasn't there!(Grind-grind)I figured this would have been a 11.5 or so if I was able to find all the gears down the track.
I let the car/clutch cool for an hour and decided to get back out there.
I ran 5 times in a row since the traffic had all but stopped and was able to improve everytime while babying the car off the line.
I ran 3 11.9's and then ran 2 11.8's before I decided to pack it up for the evening.
Best pass was 11.82@120 (1.8960ft)
I think the car has a 11.4@122 in it with some tuning and a better clutch.
I am very pleased with the car and the Magnacharger set-up I don't think there was anyother cars there that went into the 11's while getting over 30mpg on the drive up!
Old 03-28-2005 | 08:10 PM
TORCHD U's Avatar
Good times man, yeah these damn stock clutches suck - Its horrible going for the peddle and its already on the ground!
Old 03-28-2005 | 09:25 PM
Robert56's Avatar
Those are some nice times. Yea, the 1st to 2nd can be brutal, and those poor Viper bastards don't have active handling to keep the crash factor down. Many a Vette has been saved by running in Comp mode (AH). If your getting these times already I agree there is more to be had.
Old 03-28-2005 | 09:35 PM
JBsZ06's Avatar
Thumbs up
Thanks for the heads up..
Congrats ..your cars awesome.
Old 03-28-2005 | 11:15 PM
BlownChevy's Avatar
blownerator
Nice runs! glad to hear everything went well.
Old 03-28-2005 | 11:32 PM
H-5-L's Avatar
A buddy just installed one,his a/f ratio was so lean on the top end,he couldn't run WOT until getting a fuel booster pump.
Watch that clutch homie.....you need your right foot..I'm suprised you made even 5 passes on that clutch..Scarey dude..scatter shield is a word that comes to mind.
Nice times for sure even if the tune is off.
Old 03-28-2005 | 11:37 PM
xp3nd4bl3's Avatar
Moderator
I'm going to steal that car when you're not looking, Hammerboy! It's rad. It's like a supercar with the Magnacharger on it. Credit to the people who spent two months convincing you to run it on at least ET Streets...
Old 03-28-2005 | 11:39 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Nice runs! That would be low 11s at a sea level track in decent weather.
Glad to see more Vette owners driving them like they should
Old 03-29-2005 | 08:00 AM
Z06 Steve's Avatar
get a tune asap
Quick Reply: Ran my 04 Magnacharged Coupe this past weekend.
