Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Cam install pics?
Old Nov 13, 2001 | 12:26 AM
66ImpalaLT1's Avatar
Default Cam install pics?
Does anybody have any cam install pics?
I ordered a T1 from the MTI sale and I'll be installing it early spring after I collect some more parts.
Eric
Old Nov 13, 2001 | 10:00 AM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: Cam install pics?
Those pictures might scare you on a C5 install haha. The entire front steering assembly must be dropped to access the crank pulley bolt and remove the pulley. What fun!
But, the valvesprings are much easier to install on a 'Vette compared to an F-body.
Tony
Old Nov 13, 2001 | 10:21 AM
I'm not afraid, I've done a cam install on an LT1 f-body <img src="images/icons/grin.gif" border="0">
I've got a pretty good idea of what to do but I like looking at pictures. I'm definately going to order a helms manual before I start.
Eric
Old Nov 13, 2001 | 10:32 AM
http://www.corvettemagazine.com/2001...cam/campg1.asp
In case anyone else is interested, that article has some good info. There are some inaccuracys, like 24 ft/lbs where it should be 240 ft/lbs.
Eric
Old Nov 13, 2001 | 03:17 PM
AgaveCorvette's Avatar
I'm doing an LS6 cam this winter. I'll have pictures and a website up when completed. <img src="images/icons/smile.gif" border="0">
Old Nov 13, 2001 | 08:26 PM
Scalpel's Avatar
66ImpalaLT1 and Agave, I cut and pasted that link 66ImpalaLT1 posted into a chronlogical word document. Now, all we need is to make a chart of all the correct torque specs needed and of all the tools, supplies (gaskets, locktite, Sharpies), etc that will be need to finish the job properly and efficiently. I can send ya'll the word document if ya'll wanna see it. Thanks.
Old Nov 15, 2001 | 08:08 PM
Dave F's Avatar
http://www.metricchemical.com/engine.html
although not a cam install exactly, it shows everything that you need to see.
torque specs are at:
http://www.metricchemical.com/C5torque.PDF
Old Nov 15, 2001 | 08:09 PM
Dave F's Avatar
And by the way, you don't have to drop out the steering. Just disconnect it and slide it out the passenger side under the frame rail. It is tricky, but not too bad.
Dave
