Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Help with C5
Old Aug 22, 2005 | 09:41 PM
SexySS's Avatar
Default Help with C5
If anyone has pictures of the underneath of a 99 Vette, i have a wire hangin not sure what it is.. its steal braided trying to figure out what it is thanx
Old Aug 22, 2005 | 10:02 PM
BadMonkey's Avatar
about where on the car is it? I got the entire bottom of my car pulled I am sure I can figure it out when you say abotu where it is.
Old Aug 22, 2005 | 10:32 PM
SexySS's Avatar
I will try and describe it... there is like like a flat piece half way in the middle of the car maybe tranny cover thats where it hides... i am sorry i really dont know its not my car
Old Aug 22, 2005 | 10:48 PM
BadMonkey's Avatar
hard to say that area is the tunnel brace. Most wires in thereare behind the brace. The metal piece you are seeing has a bunch of bolts holding it up in there about the exhaust right? IF that is what you are looking at then that is what it is. Chances are its somethign aftermarket because there is no steel braded lines in that area. Could be a old wire from a nitrous setup maybe or a cutout possibly, returned to stock. Most wires are above that brace are OEM, and the black plastic tubing around it. Is it closer to the engine or the rear. Cause other wise it might be the wiring for the rear O2 sensor, or a wire to a O2 sim I suppose If its disconnected and you are not getting any lights or codes its nothign I would worry about persoanlly. A pic would really help. Cause I am shoting from teh hip lol
Old Aug 22, 2005 | 11:27 PM
SexySS's Avatar
i will take pic tomarrow Am and post them up thanx
Old Aug 23, 2005 | 05:51 AM
XTrooper's Avatar
The only steel-braided line under my C5 is the nitrous line!
Old Aug 23, 2005 | 05:52 AM
SexySS's Avatar
Im not saying its not possiable but i doubt it because this car is bone stock still has skip shift on it and everything got it from a corvette dealer... possiable but doubt it
Old Aug 24, 2005 | 05:03 PM
SixPak's Avatar
FWIW...a friend of mine who dabbles in two way radio quite heavily actually runs ground straps to his exhaust pipes to cut down on radio interfierance(sp?) created by the electrics of his car/truck being transmitted by the exhaust system.
Like I said, he's kinda heavy into this sort of thing.........
Old Sep 4, 2005 | 04:37 PM
BonerBen's Avatar
sounds like a ground.
Old Sep 5, 2005 | 02:13 AM
Stu's Avatar
Stu
O2 sensor wiring has a covering that looks like steel braided line.
Old Sep 5, 2005 | 09:29 PM
miniklr's Avatar
I was thinking the same thing. Ground wire.
Old Sep 13, 2005 | 09:14 PM
98LSVETTE's Avatar
I agree with STU. I had my exhaust system out last weekend and all of my O2 sensor wires had a steel braided looking cover over the wires
