How to get a 2000-03 Vette into the 10's?
How much RWHP do I need?
What is the easest way to get that power?
What needs to be upgraded so it won't break?
Thanks
True. I haven't needed one, yet. I would get the DTE brace, which I have, that eliminates, or helps to eliminate the binding/twisting of the trans and diff,...to prevent the output shaft from breaking...
A nasty cam, and heads will get you there but,..your gonna need a GEAR,..and alot of traction. Spray would get you there for sure. I would go with heads and cam, and spray. About a hundred shot, to a 150 shot. TNT F1 kit. That way, all you need is a sticky tire,...and a heavy right foot, and a quicker left foot, if you get a six speed, which I recommend.
Twin turbos is definitely my preferance.
Obviously you'll very likely need to harden several components in your drive line.
Mark
My question about the procharger system is will a procharger on a relatively stock motor make enough power to run that fast. I really didn't want to rip into the engine if I didn't have too. But I'll have exhaust, MAF, and TB upgrades, basically all the easy stuff.
Also, I think I'd like to do this with an automatic car, any thoughts?
The procharger at 7psi , full exhaust and a good tune should make 500-ish to the wheels on an LS1. Stock motor can handle 7psi. I dunno anything about the auto trans, but i'm sure other will chime in or you can search. If you get a 4000 stall like some of these guys you will launch off the line in your powerband which = insane
or cam only on the juice.
I'd go with H/C, Stall, Gears, Slicks, full intake and exaust, and spray 100shot maybe even 150shot. And that will get you in the 10's.
Beware your rear end will break if you don't do something with it. I.E. get one built or have hardened gears and output shafts installed. I broke my outputshaft with drag radials and only running 12's........
JMO
JEFF
Now the tracks are closed for winter.........
