spraying c6 zo6?
You are right. I heard the walls of that block are extrememly thin also. I would suggest to do a head and Cam upgrade which would be safer than being the guinnea pig to see what the block can handle. Or if you are spending that kind of money on a Vette why dont you just take it to a professional who can tell you what it can hold.
You should use HPtuners or LS1 Edit..Will allow you to retard around 1 degree of retard for every 50hp shot of NOS. So you would be looking atleast 5 degrees of retard at the minimum on your max timing..and run a TR6 NGK plug also or even one colder than that if you want
427 cid Aluminum C5R blueprinted block
512HP with advertised 500HP
Aluminum block w/104.8mm bores & pressed-in liners
Forged steel crankshaft with 101.6mm stroke
6-bolt forged steel main bearing caps
Titanium connecting rods
Cast Eutectic aluminum flat-top pistons
Racing-derived CNC-ported aluminum heads w/ 70cc chambers
56mm titanium intake valves
41mm sodium-filled exhaust valves
11.0:1 compression ratio
Composite manifold with 90mm single-bore throttle body
Camshaft with 15mm (.591-inch) lift
Dry-sump oiling system
7000rpm redline
Weight: 2900 lbs
Rear spoiler
Functional air induction from hood vent
Hydroformed aluminum chassis*
7000rpm redline
Weight: 2900 lbs
Rear spoiler
Robert
