'03 Corvette Z06 Upgrades
This would be a good start, i am getting a NOS kit installled on my 01 Z06. with a 150 shot you should be around 575-600 w/ cam, headers, 150 shot
FYI ls6 only has 1 cam and they don't use chips (custom tuning or dyno tune)
Good luck with every thing!
Thanks
2. Exhaust kooks headers or LG's *id keep the tit mufflers u will not see a gain worth the cost*
3. Corvettes dont get chips like moooostangs.. so you will need to get an LS1edit or Hptuners
4. You wil need heads to reach your goal.. you can get yours worked since 243's *ls6 casting number for heads* flow well.. or you can set up to AFR 205s.. prob want to up the Comp ratio some and have them milled.
5. Might also want to get CAI. they show great gains on vettes BlackWing, Haltach, V.Ram.. all are good choices.
6. Intake Man.. some people see great gains with a Fast 90/90 setup.
enjoy.
Ed Curtis Custom Cam
AFR 205's
LGM headers
LGM cage
Stock Ti mufflers with cutouts
Textralia clutch
FAST90 (ported by Tony Mamo @ AFR)
GM 90MM TB
4.10 gears
Tunnel plate
DTE Rear end brace
Meziere Electric water Pump
Jesel J2K rockers
Tuning by both MTI, the guys in Australia, and myself.
AFR 205's
LGM headers
LGM cage
Textralia clutch
GM 90MM TB
4.10 gears
Tunnel plate
DTE Rear end brace
Jesel J2K rockers
Have you ran at the track much? I have a simpilar set up. I just bought the car and I'm wondering what the rearend will take.
Thanks
I have an Exedy twin disk clutch and ET Streets, times in my sig achieved on the stock rear. I have some rear end mods... but they're sitting on the shelf in garage
Thanks
