Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
C6 questions
Old Jan 19, 2006 | 09:35 AM
Gauge's Avatar
11Second Club
Default C6 questions
Hey guys,
I've been trying to find some of this information, but I'm not having a lot of luck searching. If you have a good source of information where I can get details, by all means let me know!
My father is thinking about purchasing a 2006 'vette, and he is internet retarded. Therefore, I am the one stuck doing the searching. Can anyone answer a few of his questions for me?
1) What kind of differential does the C6 come with, and what kind of HP is it good for?
2) What is the gear ratio used in the differential in the C6 M6?
3) What kind of M6 tranny does the C6 use? T-56?
4) Is the stock C6 exhaust true dual?
5) What's the purpose behind the rear-mounted transmission? Any advantages or disadvantages?
Thanks in advance everyone!
Old Jan 19, 2006 | 12:29 PM
sscamaro02's Avatar
Originally Posted by Gauge
Hey guys,
1. Independent rear. Can explode with stock engine if not careful.
2. .342
3. T-56 Z51 has different gear ratios in the T-56
4. Stock C6 exhaust is true duals.
5. ?
Hope this helps you.
Visit http://forums.corvetteforum.com/zeroforum?id=74
Old Jan 19, 2006 | 12:38 PM
GTOTitoLS1's Avatar
Answer To #5; Weigth Ditribution 50%front 50%rear, Makes Car Corner Better Faster, Can Take Tunrs Alot Faster Than Most Sports Cars.
Old Jan 19, 2006 | 12:43 PM
GTOTitoLS1's Avatar
ABOUT DIFF EXPLODING, IN MY OPPINNION IT WON'T. Lingenfelter vette has over 650hp on a stock .342 . To the best of my knowledge, holds up to 750hp. But not to shure check dirrectly with GM.com
Old Jan 20, 2006 | 07:08 AM
Silver 00 SS's Avatar
Tell me if I am wrong but for the disadvantages isn’t there more drivetrain loss?
Scott
Old Jan 21, 2006 | 10:52 AM
slt200mph's Avatar
Scott
You see an F body usually put down 5 to 10 more RWHP than the stock vettes..IRS is the reason ..it uses more HP than the straight axle configuration. But the IRS is much better for handling than the straight axle cars.
Old Jan 22, 2006 | 08:23 AM
SixPak's Avatar
answer to #1,2,3, in a nutshell.
hope this help with your decision.
Old Jan 24, 2006 | 07:34 AM
kazman's Avatar
2006 has a 6 speed auto:
Six-Speed Paddle Shift with Automatic Modes
Gear ratios
First gear 4.02
Second gear 2.36
Third gear 1.53
Fourth gear 1.15
Fifth gear 0.85
Sixth gear 0.67
Reverse 3.06
Final drive ratio 2.56
