Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
Frc????
Old Feb 20, 2006 | 03:27 PM
onsracing's Avatar
Default Frc????
I'M LOOKING TO BUY A 99 AND UP VETTE AND I'VE BEEN SEEING SOME WITH A DESCRIPTION OF FRC. DOES ANYONE KNOW WHAT FRC STANDS FOR??? THANKS
Old Feb 20, 2006 | 03:28 PM
V-seriesTech's Avatar
fixed roof coupe.
Old Feb 20, 2006 | 03:29 PM
a non removeable permanent HARD TOP, think Z06 body style, without the brake ducts.
The TARGA or HATCH back, or LIFTBACK are the more common, vettes you'll see around.
http://images.kbb.com/VehicleImage/1...CHCVTHT001.jpg
Old Feb 20, 2006 | 03:40 PM
onsracing's Avatar
Ooooooohhhh! I See! Thanks 4 Da Info
CarsRFun's Avatar
dont forget fuel rail cover also...
Old Feb 20, 2006 | 03:42 PM
werd... no problem.
I'll take some strippers for my time and effort.(I don't mean wire strippers either)
Old Feb 20, 2006 | 03:48 PM
StealthZ06's Avatar
In the corvette world, it means Fixed Roof Coupe.
It was a low option, lighter, slighly cheaper Corvette. It evolved into the Z06 in 2001. It's over 200lbs lighter than a Corvette coupe.
Here's a cool picture showing all three styles. The hardtop is up front.
Old Feb 20, 2006 | 03:52 PM
Cgillies86's Avatar
Actually its about 80 lbs lighter than the auto coupe.
http://www.corvetteactioncenter.com/...9/99specs.html
if you subrtract the curb weights of the 1999 M6 coupe and the FRC you get:
3230-3174 = 56lbs
Most people tend to say 80 because most coupes are autos.
auto coupe vs FRC
3253-3174 = 79 lbs
And, if you bought a 97 vette like me the difference is even closer but not much.
http://www.corvetteactioncenter.com/...7/97specs.html
97 M6 coupe vs FRC
3218-3174 = 44 lbs
Old Feb 20, 2006 | 04:03 PM
StealthZ06's Avatar
Originally Posted by Cgillies86
actually its about 80 lbs lighter than the coupe
if you subrtract the curb weights of the coupe and the FRC you get:
3230-3174 = 56lbs, but most people say 80 because that is the difference in weight between the auto coupe and the FRC.
auto coupe vs FRC
3253-3174 = 79 lbs
97 M6 coupe vs FRC
3218-3174 = 44 lbs
You're right, I was thinking of the difference between an f-body. The Z06 took it even a little further and dropped the curb weight down to 3,117 lbs.
Old Feb 20, 2006 | 04:12 PM
Cgillies86's Avatar
I think the weight differences between the FRC and the Z06 are mainly due the Run flat tires on the FRC and the titanium exhaust system on the Z06. Also, doesn't the Z06 have a thinner windshield?
Old Feb 20, 2006 | 06:54 PM
z06matt's Avatar
It's thinner, smaller something like that I can't remember... lol
Old Feb 20, 2006 | 08:06 PM
DocT's Avatar
Yep, it's thinner, lighter, yet stronger.
Old Jun 27, 2006 | 09:12 PM
Pipelayaz's Avatar
97 to 04 C5 Z06's did not come in Targa tops? I been searching.
Old Jun 27, 2006 | 09:38 PM
Sideways240sx's Avatar
z06 is only frc. Fixed roof coupe. You can get 97-04 coupes, or converts. If you want a z06 you get frc.
keliente's Avatar
Z06's started in '01. All Z06's are FRCs.
Old Jun 27, 2006 | 09:44 PM
Pipelayaz's Avatar
Thanks a bunch!
Old Jun 28, 2006 | 02:03 AM
silver98formula's Avatar
FRC stands for Flame Retardant Carpet. Well last weekend it did.
Chris
Old Jun 28, 2006 | 10:07 AM
jbusmc1986's Avatar
Default Not really
True all ZO6'S ARE FRC'S BUT all FRC's are not ZO6'S through 2001 all FRC (Fixed Roof Coupe) cars were lighter, cheaper and had usually less options... all were equipped with the m6 trany ... I am not sure of the standard diff... Mine came with the 3.42 gertrag... same as the Z. Starting in 2001 the only FRC cars that you could get were the ZO6's.... I hope that this helps.
Old Jun 28, 2006 | 07:48 PM
Ell Ess Won's Avatar
yep, 99-00 FRC was only m6 with the Z51 suspension as standard, as opposed to optioned on the coupes.
