Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
C5 Z06 weight reduction ???
Old Feb 21, 2006 | 03:05 PM
M6HuggerSS's Avatar
Default C5 Z06 weight reduction ???
just wanted to know if anyone here has done any weight reduction to there C5 Z06's
if so, please list what you removed, and there weights if you have it...
and your before and after curb weights if you have those numbers also
thanks guys!
Old Feb 21, 2006 | 03:07 PM
TonyJ's Avatar
Well, I try to keep my wife out of mine...
Old Feb 21, 2006 | 03:31 PM
MGorman's Avatar
Not totally relevant, but I had my C5 coupe weighed recently. With no weight reduction it weighed 3163. A Z06 should be a bit lighter.
Old Feb 21, 2006 | 07:15 PM
Matt SS's Avatar
Why would you want to???
It weighs 3086lbs now, GREAT power to weight ratio!
Old Feb 21, 2006 | 07:27 PM
Assassin's Avatar
its called eating less.... but seriously, there isnt much weight to be shaved off and still have a good comfortable car, the first place I would look would be the most expensive and best light weight rims, I think that would make a bigger difference than any weight reduction you could do.... and run it a 1/2 tank of gas, no washer fluid, light weight batt., I guess those types of things would help also...
Old Feb 21, 2006 | 07:32 PM
Sigforty's Avatar
My Z06 weight was around 3168 with a full tank of gas, and some extra stuff in the trunk (5 quarts of oil, tools, flashlight, and a few other things). I figure the car only gets lighter from there when I carry less and have less gas in the tank. I wanted to know the worst possible weight so I put in some extra stuff.
Old Feb 21, 2006 | 08:01 PM
Z O SICK's Avatar
Mine weighs 3080lbs with heavy aftermarket 18 x 10.5 rims all around and half a tank of gas.
Old Feb 21, 2006 | 08:22 PM
ChucksZ06's Avatar
Aftermarket brake rotors, lightwt wheels, check the tire weights (you would be suprisied how much heavier some tires are than others. This is all rotational weight which makes a noticeable difference in performance. Also headers and custom exhaust can pick you up some. It is not easy to take more than 50 lbs out of a z06 without stripping it of the obvious creature comforts.
Old Feb 21, 2006 | 09:25 PM
M6HuggerSS's Avatar
thanks for the info guys....
i figured a few pounds could be lost by doing the LG lt kit... maybe shave 25lbs over the stock cast iron manifolds. maybe save 10lbs with a lighter batt.
how much does the a/c weight in a Z06? same as an f-bod?
Old Feb 21, 2006 | 10:05 PM
cantdrv65's Avatar
Post
Slicks and skinnes are about the only weight reduction Id do....
Old Feb 22, 2006 | 08:36 PM
ChucksZ06's Avatar
If you have the stock battery keep it...I weighed mine and it was as light or lighter than an optima...GM spent a lot of money to get this car as light as it is so it is very hard to improve on that.
Old Feb 22, 2006 | 08:42 PM
DocT's Avatar
What he said! Definitely difficult to do!
Old Feb 23, 2006 | 11:59 AM
hyde's Avatar
I just make more power...I change the Jets....lol
Old Feb 23, 2006 | 01:45 PM
marcus769's Avatar
LOL! "keep my wife out!" HAAHAHAHAHAHAH Damn, thats funny!
Nice/informative thread guys! There isnt really a whole lot to do!
Old Feb 23, 2006 | 03:18 PM
slt200mph's Avatar
Shipping weight on a Z06 as they came from the factory with about 2 gallons of gas in them was 3045 pounds..it was printed on the cars invoice...I like the "I try to keep my wife out of it" comment...still chuckling on that one.. ..
Old Feb 24, 2006 | 02:47 PM
kyle`s 02 vette's Avatar
Default lbs
my 2002 coupe with 1/2tank full 15pound nitrous bottle and me in it was 3260 and im 180
Old Feb 25, 2006 | 07:37 AM
slt200mph's Avatar
The only way you could get to that weight is to pull some weight out of the car..or you were on a an incorrect scale..
Old Feb 25, 2006 | 09:08 PM
its the scale at houston raceway park i guess it could be off but every time i have been the its always close to that number so
Old Feb 26, 2006 | 02:08 PM
FACE's Avatar
3340 with my 180lbs *** in it. So that's 3160 with a 5 point roll bar, skinnies, no cats, etc.. in my 98 Coupe.
Old Feb 27, 2006 | 08:34 AM
slt200mph's Avatar
I am amazed at all the F body cars that are lighter than a Corvette..C5 Corvette coup (1997-2994) is over 3200 lbs...the only way to get to these weights if they are correct is to lighten the car..
