Engine Removal for Cam swap??
I have the LS1/ LS6 V8 book written by Will Hendzel and he recommends removing the engine from the car, which brings me to my problem of being 8 hours away from my Pop's garage.
If you have done it in the car, any pics or directions would be nice.
For sale : Comp Cams # 54-000-11 / G5X-2 Hyd. Roller Cam for LS1,2,6. 1997-up. 232/240 dur. @.050" . .595/.608 " lift. on a 114 LSA. Comes complete with exact matching Comp Cam. Sring Set # 26918-16 and exact matching TrickFlow ChromeMoloy Pushrod set # 7.400 / .080 .
Lope at idle. (Idle needed to be set at 950 rpms)
Parts have less than 200 miles on them and are excellent in every way. No scratches..totally perfect. The 3 pieces ran $679 total. Will sell for : $425 total and ill pop for shipping to you.
Will give money back guarantee .
Dyno showed this set adding an additional 62 rwhp. on a 2006 LS2 Corvette.
Email me : Fast1970vette@webtv.net (dave)
The steering rack was a PITA, but I like what SPANKY did with his and that will probably what I do next time! Cool post Spanky!
Micah
Micah
You need to drop the k-member to clear the oil pan on its way out the top.
as said, drop the xmember about an inch and the rack will slide out the drivers side, shouldn't take more than 20 minutes to remove, 18mm on the pres/ret lines, rem. the steering shaft(13mm)from the top w/ the alternator out
