Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
What times for modded c5 guys
Old Jul 13, 2006 | 11:04 PM
madradvette00's Avatar
12.1s
Old Jul 14, 2006 | 12:30 AM
O2Thief's Avatar
Times in sig. That was w/ a 1.90 60' on radials.
Old Jul 14, 2006 | 02:57 AM
silver98formula's Avatar
TPis LT's, Vararam, SLP Loudmouth, and a 150shot I ran 12.0 (off idle launch) at 125 Only if the car would 60ft. Low 11's would be nice.
Chris
Old Jul 14, 2006 | 04:37 PM
ChiefDave's Avatar
12.3 @ 114, bad air (hot humid) cai
11.82 @ 118 with LG Pro Lts, CAI and MT ET st radials (1.70 60)
11.50 @ 120 224 227 .580 .580 114 (TR blower cam), aussie clutch, dte brace and hardened out put shafts (1.5 60)
now with HC, gears, skinnies and ET st bias ply, I run 11.4 spining thru 1st with 1.60 60s... but I hope to run tomorrow @ Carolina and hook the beothc and go 1.4s and 11.0s @ 123ish
Dave
Old Jul 14, 2006 | 06:46 PM
AOC's Avatar
AOC
LT headers, CAI = 11.9@118.9 1.911 60' with street radials
With N2O = 11.3@126.3 1.820 60' with street radials
Old Jul 14, 2006 | 11:37 PM
racerrob333's Avatar
chiefdave well if your going to the house of hook you can bet you will hook or break
Old Jul 15, 2006 | 12:34 AM
zo6vetteman2003's Avatar
Dave
Have to see what Geneus runs at E-town hehe.
Old Jul 15, 2006 | 02:14 PM
c6_dave's Avatar
nice ride! Wonder what you'll get with a good set of slicks and if your bottom end holds together
Glad to see Chiefs make more money than they did when I was in!
Aviation Ordinance, correct?
Old Jul 15, 2006 | 02:50 PM
usd2sing's Avatar
7lbs boost, a4, 2800stall. 1.55 60ft.
see sig.
Old Jul 15, 2006 | 04:38 PM
AOC's Avatar
AOC
Heh, I've made at least 300 passes and I'm still on stock clutch. I don't know how long my clutch will hold up but last night while I was racing against stage 3 skittle, I chirped 4th gear so clutch is doing just fine for now.
With DRs, I'm pretty sure it will run high 10s based on my trap speed, providing my half-shaft holds up, I think bottom end should hold up just fine.
Yes, Aviation Ordnanceman, I'm out of the Navy now, currently designing future combat aircraft for the Navy and Air Force.
Old Jul 16, 2006 | 02:03 PM
PurpleHaze98's Avatar
12.98 at 111 60' 2.13 shitty launch 80 degrees 92% humidity 1st time at teh track cam only small cam at that on a dr.
Old Jul 17, 2006 | 07:45 AM
  #32
itsfast's Avatar
Only 1/8 mile track here, but here are my results.
My last car was a '00 A4 coupe: Patriot Stage 2 heads/Comp cam (224/228), headers, built tranny, bfg dr's, tune. 6.87 @ 103 with a 1.6x 60' (converts to around a 10.7 pass)
Current '02 Z06 with headers, high flow cats and borla stingers with MT ET street DR's. 7.53 @93 with a 1.64 60' (converts to around an 11.8 pass)
