Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
What times for modded c5 guys
Old Jun 24, 2006 | 08:38 PM
Mr.Nitrous's Avatar
Default What times for modded c5 guys
What times are most of you guys running with a modded c5? Mods like head/cam, full exhuast and all the other stuff that goes along with it.
Old Jun 24, 2006 | 08:50 PM
NEED2SPEEDLS1's Avatar
i got some buddys with modded c5's running in the mid 11's. mild cam, full bot ones, and a decent set of heads, My other friend was running a beefy heads,cam,50 shot, bolt ons, suspension. he touched 10's with it. cant remember exact time but i think high 10's
Old Jun 24, 2006 | 08:59 PM
99SLOWC5's Avatar
cam only on slicks I went 11.45@119
TSP 233/239
slicks
pt4000
3.90 gears
headers
tune
JEFF
Old Jun 26, 2006 | 04:03 PM
DBN's Avatar
DBN
10.6 @126 for my 346 ci N/A A4 coupe.
Old Jun 26, 2006 | 05:29 PM
pdd's Avatar
pdd
heads-cam-90mm fast ,long tubes,etc...
13.9@114
my first time at the track, i had sum massive wheel hop that day and blew my rear end
should be an 11second ride though, just not wit me driving, needless to say i need lot more seat time
Old Jun 26, 2006 | 09:15 PM
Sigforty's Avatar
Cam with bolt ons and tires had me doing 11.7s down here in Louisiana.
Old Jun 27, 2006 | 11:01 AM
ROJO99's Avatar
Here is my progression. Ride is a 99 FRC, enough said...
Stock 13.22, 60' times where horrid 2.2's.
Added Goodyear F1GSD3's, Raptor Shift Light and Ripper Shifter,
12.92.
Added Blackwing.
12.91.
Added BFG DR's on the rear and Vararam VR2B and an LS6 intake.
12.55.
Added Melrose LT headers, Random High Flow CATS and X-pipe.
12.20.
Added Thunder Racing 230/224 575/563 111LSA Cam.
12.32, with clutch not gripping like it should.
Took off the DR's put the F1GSD3's back on to help the clutch last a little longer and with all the above mods.
12.3 all day with 2.0 60's.
Now its clutch time to hunt for the 11's. Please note, I am still running stock mufflers. Quite as can be .
Old Jul 6, 2006 | 09:29 PM
N2O4YOU's Avatar
Ran 11.9 on motor and 10.9 on Nitrous with mods in sig.
Old Jul 6, 2006 | 09:59 PM
chevynation's Avatar
wow you guys are fast... faster than i thought possible for something with IRS. did you have to do geometry or strength mods to run those 10s/11s? i'm asking bc i keep hearing the IRS on goats and 03 cobras suck. strangely those cars don't even handle either.
Old Jul 7, 2006 | 03:26 PM
robz*'s Avatar
I agree!
Old Jul 7, 2006 | 03:43 PM
keliente's Avatar
Keep this thread going, I want to know what kind of times I should be shooting for (98 MN6, catback & vararam).
Old Jul 7, 2006 | 04:22 PM
Kraest's Avatar
I did the following in my sig the other night with a brief cool-off and no changes to anything (not even tire pressure) in 80 degrees and 80% humidity (TERRIBLE weather for a blower).
I expect low 11s @ 125+ out of it in good air all with a 2400 stall.
Old Jul 10, 2006 | 06:27 AM
allthrottle&nobottle's Avatar
Times in the sig.......
97' has a little stroker......
00' vert bolt ons, stock short block
00' coupe just CAI,LT, Tune & catback
Old Jul 10, 2006 | 07:07 AM
red91sc's Avatar
Seems like adding a sc to the C5 and your pretty much set on low 11's....Is there a quarter mile list for the C5's with what mods they have?
Old Jul 10, 2006 | 09:29 AM
corvettelover's Avatar
I'd like to know this as well. 98 auto with a NX 100shot, or NX 150shot.
Are 11's achievable with the above mods, and 100 or 150 wet shot?
Old Jul 10, 2006 | 01:10 PM
Shackleford's Avatar
Definitely with a 150 shot.
Old Jul 10, 2006 | 02:35 PM
robz*'s Avatar
With a good s/c setup today you can make 600rwhp. That should put you in the mid -low 10's once you learn how to put all that power to the ground. It will take some seat time and maybe some broken parts as well.
Old Jul 10, 2006 | 02:44 PM
racerrob333's Avatar
I run 10.40 at 133 running about 12 lbs boost and a 50 shoot on et streets
Old Jul 10, 2006 | 04:02 PM
red91sc's Avatar
Stock bottom end?
Old Jul 10, 2006 | 05:23 PM
oh no pro mod rods, je pistons ,afr heads, all the good, 60 ft sux 1.67 I got me some 28 inch slicks to go on my ccws Im going back to the track the 22 of june at reynolds
