Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
competitive mode??
Old Sep 5, 2006 | 07:15 PM
CamaroSS621's Avatar
Default competitive mode??
on a C5 Z06??? How does that work??
Old Sep 5, 2006 | 08:00 PM
DocT's Avatar
basically, it turns traction control off, while leaving the active handling mode on in case your car decides to get a little sideways. You can access this mode by holding down the traction control button down for 5-7 seconds, and on you information display panel it will say "competitive driving mode." Very cool feature.
Old Sep 5, 2006 | 08:36 PM
longdaddy's Avatar
in simplest terms, it will apply individual brakes if the angle between where the front wheels are pointing and the actual direction of the car reaches a certain threshold. it will try to correct it to bring the car under control. it will NOT "save it" if you really overcooked it in a turn, but it can mean a difference between a "close one" and wrapping the car around a tree or kissing the concrete.
Old Sep 5, 2006 | 08:44 PM
will it do anything for drag racing?
Old Sep 5, 2006 | 08:55 PM
Ranger's Avatar
King of the radial tires
Comp Mode will help you stay off the wall in case your rear end gets loose, but can't defy the laws of physics if you keep the throttle hammered.
I made all my passes in Comp Mode and it didn't effect my times adversely. People that say Comp Mode is slower in the 1320' are FOS.
On my C5Z06s the rear end came loose on two of 500 passes, and Comp Mode saved me both times. Conversely, I've seen five C5s hit the wall at the drags and all had the active handling computer turned off. Very dumb driver error.
Ranger
Old Sep 5, 2006 | 08:59 PM
thanks ranger. ill try it next time
Old Sep 6, 2006 | 11:33 PM
Sigforty's Avatar
Well put, but one more thing to add if you want to clear the Comp driving message hit the reset button.(the car will stay in comp mode, but let you access different DIC functions) I often do this because I will watch the temps of the car while in the staging lanes.
Old Sep 6, 2006 | 11:49 PM
viper9403's Avatar
Is this only on the Z06?
Old Sep 7, 2006 | 03:40 AM
Ranger's Avatar
Active handling is standard on all Corvettes starting with model year 2001. And it was optional equipment from mid-year 1998-2000.
One more thing. If you're in Competitive Driving mode and then recycle the ignition (turn it off and then on again, for example after stalling the car), you must re-enter Comp Driving mode again before doing the burnout and making the pass.
Ranger
Old Sep 7, 2006 | 01:06 PM
Z O SICK's Avatar
Ranger
Same here! It saved me a few times at the track! Without comp mode, I would of hit the wall.
