Help! P1134 & P1154 HO2S Transition Time Ratio
Hey All,
I have just put in my new headers a couple of weeks ago, and I'm getting a few unexpected codes.
First, the info: The headers are the ebay LT's with ceramic coating on the outside, and I'm running the rear O2 in the front on the driver's side and an LC-1 wideband on the pass. side; the rear O2's have sims in place. I originally was only getting P1134 within a few days of driving, which is for the drivers side, but now I'm also getting P1154 for the pass. side.
I have found lots of info for troubleshooting these codes, but I thought I'd throw it out to you guys for your expert advice. There are no exhaust leaks, and I pulled the LC-1 last night and it looks clean as a whistle, so I don't think there is any contamination of the sensors. Any ideas??? The car runs great, by the way.
Thanks in advance!
Brent
Thanks in advance!
Brent
I dont not know if the front and rear o2's are interchangeable. I know they have a diff part number. Maybe try using correct front o2's? Maybe the left and the right are switched? Those are my guesses.
Chris
Chris
The rear O2's are not the same as the front ones. If they are installed wrong it will throw codes.
plus a wideband I thought was for tuning the car only? maybe I am missing something.
You should have the same O2 sensors in the front. Buy the correct ones for the fronts.
