Corvette Performance
C5 | Z06 | C6 | ZR1 | C7
07 C6 Intake/Exhaust
Old Oct 3, 2006 | 09:03 PM
CK9887's Avatar
Default 07 C6 Intake/Exhaust
My friend is buying an 07 C6. He wanted me to do some research on the intakes and exhaust.
Im not too farmiliar with C6s. But I know with F-Bodys, the cheapest way to upgrade the intake is just replacing the lid. Corvettes seem different though. Can you replace the corvette lids? Or is it like a whole system?
I know SLP and K&N make kits. I've also heard good things about the Varram kits but we will be driving this car across country in December so I would be worried about water getting inthe Varram.
Now, Exhaust. Ive seen several different setups. Hes mainly just wanting a cat-back... What would be the best setup keeping stock headers. Ive seen Setups inlcuding the X pipe w/out cats and also setups with just the mufflers....
Like I said, We are driving this car across country in December so practicallity is a must... Basically he is just looking for to add a few horses and tone up the exhaust.
So what would yall reccomend.
Thanks
Old Oct 4, 2006 | 09:26 AM
marcus769's Avatar
Corsa/Borla are very good, but expensive. Depending on how loud you want it, do some searches. This topic has been talked about 9876876988968976 times at least.. There are sound clips all over the place. Good luck!
Old Oct 4, 2006 | 10:52 AM
BigRon77's Avatar
The CAI is a whole replacement from the MAF forward...i.e. air bridge and filter. If you are concerned about water issues, then stay with a Halltech Stinger or K&N. It's not really that big of a concern with the other intakes like LPE (which I run) and the Honker, both of which breathe from the bottom (requires cutting the radiator shroud). I've got 15K miles on mine driven in all conditions other than 2 feet of standing water at WOT...you can't be completely nuts, but I would go cross country, no problem.
I run the Magnaflow catback with x-pipe (and had it before headers, etc.). It's a very deep note, quiet, very loud/aggressive at WOT, and no difference in noise at highway speeds from stock. It's like the Borla Touring at all levels except WOT, where it is much more aggressive. It's expensive, but very good quality. X-pipe isn't necessary if he plans no more mods. If he wants a little more hp, then go x-pipe and get the Magnaflow hi-flow cats, which are direct bolt-on replacements to the stock cats.
Good luck!
Old Oct 4, 2006 | 09:13 PM
CK9887's Avatar
Thanks for the help...
Now do they make like a K&N filter that just drops in the stock airbox?
Old Oct 4, 2006 | 09:29 PM
BigRon77's Avatar
They do. There are two filters (split on each side). They are about $40 each.
Old Oct 4, 2006 | 09:32 PM
CK9887's Avatar
Ok cool... Is there much advantage of the full K&N system? Cause it seems with the full system, the filter is exposed which means it could be sucking in heat from the engine bay?
Old Oct 5, 2006 | 10:48 AM
BigRon77's Avatar
It's not any worse than the stock system, which is just a plastic cover over two filters...same heat still gets in. The Vette breathes from the bottom and sends "charged" outside air to the area where the filters are located.
The supposed advantage to the single filter (besides the fact it's huge and can get more air), is that it stops the stock air intake from breathing from both sides and swirling the air to the MAF.
To be honest, and in most people's opinion, including mine, the CAI on these cars do very little unless you go with a true bottom breather/vararam. Not worth the money unless you intend to do more mods. You can drop the K&Ns in and get rid of the crappy stock paper filters.
Exhaust doesn't do a hell of a lot either. I picked up 11hp (could have just been a better dyno day) with the Magnaflow exhaust (with x-pipe) and halltech stinger (basically big K&N filter). Certainly not worth $1800 for the performance...sound is totally up to you.
Old Oct 18, 2006 | 02:38 PM
CK9887's Avatar
Well after listening to some sound clips The Corsa Sport system seems to have a nice aggresive sound to it... What do yall think?
http://www.corsaperf.com/c6.htm
