C6 Headlights.
C6 Headlights.
I have a question on this style headlight.
I know the C6 uses HID low beam lights with a projector housing. Is the High beam an HID light as well, or is it a Halogen?
I did a little research and now I'm thinking they are low beam HID only.
Reason I ask is for a non pop up swap over on my TA. I'll either use these, or BMW bixenon projector housings. I want to go with the C6 setup, due to the fact that I want 2 lights in each housing.
Rob
Rob
I'm pretty sure the high beams are tungston/halogen projectors. I'm not a headlight guy so don't ask me what that means... ask me something like the dynamic compression on a stroker with 66cc heads and a 236/242 cam
rj
rj
The high beam is not a HID as well. It is a Toshiba 9011 HIR bulb, very similar to a 9005 bulb but it puts out a lot more light. I did the 9005 modification on a set of these Toshiba 9011 HIR bulbs and installed them in the low beam sockets of my 00 Vette. Big improvement. Way better then Sylvania Silverstars.
