Long Tube Clearance?
They are a PAIN to install though.
I had to losen the motor mounts and move the motor to the side.
Then once I got them installed the flange didnt match up to the heads
The passenger side slides in without issue.
Remove your spark plugs before you remove your factory manifolds, otherwise the weight from the manifolds can crack the plugs.
Have someone go underneath the car, to support the headers, so you can easily start *****ALL****** of the header bolts. You can re-use your stock bolts....and I would recommend NEW GM gaskets. NOT LS6 gaskets. But, LS1 stock gaskets. Truck gaskets work fine as well.
Kooks....seem ten times easier to installl.....from what "I" have done here. I've installed kooks...and LG's....kook are WAY easier due to the shorter length of the tubes.
Do not waste your money and put on shorties.
Peace
